All,
There is a bug in Red Hat Linux g++ 3.2.3 when -O3 is specified that
causes CA R3.14.9 to fail. The bug is known not to occur with several other g++
versions, but many versions have not been tested. I also don’t know what
versions of Linux g++ are most commonly used at the various EPICS sites.
So I am curious if this is a substantial issue for the EPICS community
or if it can be safely ignored? If defective compilers are still in widespread
use I could look for a workaround in the EPICS source code.
Jeff
During
testing of R3.14.9 I see a bug showing up only in optimized builds on Linux
using g++ 3.2.3 that I don't see with other compilers. This bug appears to be
related to failure of this particular compiler to follow the strict alias rules
specified in the standard when optimizing the byte swapping templates installed
for R3.14.9.
Problems
Red hat Linux g++ 3.2.3 when -O3 is specified
No problems
mingw g++ 3.4.2 -O3
Tornado 2.02 g++ -O2
Microsoft C++ 2005 full optimization builds
______________________________________________________
Jeffrey O.
Hill
Internet [email protected]
LANL MS
H820
Voice 505 665 1831
Los Alamos NM 87545 USA
FAX 505 665 5107
