Ralph,
that's probably not the only CA problem in 3.14.9.
In May, I repored a bug to the Mantis bugtracker which has not even been
assigned until now. (Maybe posting it to tech-talk helps.)
Summary
long integer values are corruped in R3.14.9
Description
When writing integer values with a CA client (e.g. medm) to a long integer channel (e.g. longout record), the upper bytes get corrupted. The lower 2 bytes are OK.
I can't see the error when the client is caput from base.
Client and IOC run on a linux-x86 machine.
The problem is new in 3.14.9.
It seems some things in CA have been changed in 3.14.9 and not to the
best. I just don't use 3.14.9.
Dirk
Ralph Lange wrote:
More observations from me:
I can also see the faulty behaviour against a Linux 3.14.9 IOC.
Including the statistical behaviour that Steven was reporting. Some of
the caget calls get the unexpected "no read", others don't. On the same
Linux host, caget fails about 20%. Cross to vxWorks mv2100 IOC, caget
fails 100%. Camonitor works all the time, against all type IOCs.
Rebuilding Base 3.14.9 with the as subdirectory from 3.14.8.2 does not
change the faulty behaviour at all. The as parser cleanup things got away.
More observations from Steven:
I already have optimization turned off for the cross compiler (have been
bit by that on VxWorks before) but have host optimization on. I tried
turning off host optimization and recompiling caget on linux, but the
problem remained.
Now, I just rebuilt all of base on linux with HOST_OPT=NO. Even stranger.
Using optimized build on linux, caget failed with an unexpected read
access error 19 out of 20 times just tested. Using non-optimized build
on linux, caget failed 2 out of 20 times!
Houston, we have a problem.
Ralph
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- Re: Possible Bug in 3.14.9 Access Security on mv2100 Kay-Uwe Kasemir
- Re: Possible Bug in 3.14.9 Access Security on mv2100 Andrew Johnson
- Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
- Re: Possible Bug in 3.14.9 Access Security on mv2100 Steven Hartman
- Re: Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
Re: rpath compiling? Dirk Zimoch
RE: rpath compiling? Adams, Billy R. (LARC-D401B)[RAYTHEON TECHNICAL SERVICES CO]
<2007>
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
