1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Possible Bug in 3.14.9 Access Security on mv2100
To: EPICS Tech Talk <[email protected]>
Date: Wed, 08 Aug 2007 17:46:10 +0200
More observations from me:
I can also see the faulty behaviour against a Linux 3.14.9 IOC. Including the statistical behaviour that Steven was reporting. Some of the caget calls get the unexpected "no read", others don't. On the same Linux host, caget fails about 20%. Cross to vxWorks mv2100 IOC, caget fails 100%. Camonitor works all the time, against all type IOCs.
Rebuilding Base 3.14.9 with the as subdirectory from 3.14.8.2 does not change the faulty behaviour at all. The as parser cleanup things got away.
More observations from Steven:
I already have optimization turned off for the cross compiler (have been bit by that on VxWorks before) but have host optimization on. I tried turning off host optimization and recompiling caget on linux, but the problem remained.
Now, I just rebuilt all of base on linux with HOST_OPT=NO. Even stranger.
Using optimized build on linux, caget failed with an unexpected read access error 19 out of 20 times just tested. Using non-optimized build on linux, caget failed 2 out of 20 times!
Houston, we have a problem.
Ralph
Re: Possible Bug in 3.14.9 Access Security on mv2100 Dirk Zimoch
Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
Re: Possible Bug in 3.14.9 Access Security on mv2100 Steven Hartman
Re: Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
Prev: Re: Possible Bug in 3.14.9 Access Security on mv2100 Ralph Lange
Next: StripTool Y range LYNCH, Damien
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Possible Bug in 3.14.9 Access Security on mv2100 Dirk Zimoch
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
