1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Embedded EPICS IOC
To: Mauro Giacchini <[email protected]>
Cc: [email protected]
Date: Fri, 03 Aug 2007 07:02:31 -0500
mauro,
what i'm doing for the ebrick is to build an epics application on a host with the native compiler, then copy it to the target
ioc. both host (full blown linux version) and target (stripped down linux version) machines for the most part have the same images,
libraries, etc. i haven't had any incompatibilities between the host and target. i've created my own architecture so as not to confuse it
with linux-x86. i build using 'no share' and 'static' in config_site. here's a link to the ebrick web page. incidentally, the newer ebrick's
have a real-time kernel (2.6.19/w rt patch from osadl) and can boot using a hdd, compact flash, usb stick, and from the network.
http://www.aps.anl.gov/aod/bcda/synApps/ebrick/ebrick.html
hth,
/david
Mauro Giacchini wrote:
In the EPICS wiki-pages there is a document which may give you someone hints:
http://www.aps.anl.gov/epics/wiki/index.php/HowToPC104
Hope this helps
Mauro.
David DeBonis wrote:
We are working on an embedded EPICS IOC deployment but are running into some confusion on what is necessary to build to our target architecture which is ARM running a linux kernel 2.6.x. We have our own cross-compilers that we would like to use and build with but we seem to be running into issue with some post-build executables that need to be run on the target.
Can someone clarify what EPICS binaries are necessary to be deployed to the target to run as a "Soft IOC" standalone? Also, can we cross-compile all we need on our host system yet run fully standalone on the target?
Just to be clear, we are not running as a slave target to a host computer but as a fully standalone embedded host IOC.
Any clarification is deeply appreciated.
*David DeBonis*
Principal Software Engineer
ZTEC Instruments, Inc.
Phone: 505-342-0132 x133
Fax: 505-342-0222
[email protected] <mailto:[email protected]>
David M. Kline                   [email protected]
Beamline Controls and Data Acquisition (BCDA)
Argonne National Laboratory, Advanced Photon Source
Argonne IL, 60439                      630.252.8639
                  Beamlines R Us
Embedded EPICS IOC David DeBonis
Re: Embedded EPICS IOC Mauro Giacchini
Prev: RE: "invalid UDP request" during boot Jeff Hill
Next: Channel Archiver | Matlab Eric Berryman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Embedded EPICS IOC Mauro Giacchini
Next: edm: bug-reports unnecessary? Ralph Lange
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
