Mark Rivers wrote:
I have found a problem in the APIs used by device support to receive
callbacks from asynDrivers. These are the callbacks that an asyn driver
supports via pasynManager->registerInterruptSource, and device support
accesses via, for example, pasynInt32->registerInterruptUser. These
callbacks allow EPICS records to have "I/O Intr" record processing, i.e.
the record only gets processed when the driver calls back device support
with "new" data.
Assuming that the only changes you'd be making to the asyn API would be
to the routines mentioned, i.e. pasynManager->registerInterruptSource()
and to methods for specific ASYN message types such as asynInt32 (but
not to asynOctet) then this should not affect my directNetAsyn layer at all.
If you make any non-trivial changes to asynOctet I'm sure mine would not
be the only code affected, but from your description it doesn't appear
that this will be necessary.
- Andrew
The right to be heard does not automatically include
the right to be taken seriously. -- Hubert H. Humphrey
- Proposed change in asyn interruptCallback APIs Mark Rivers
Re: .cmd file downloading problem Kate Feng
Re: Maximum archival rate Maren Purves
<2007>
Obituary for Coles SIbley who worked with our community at MIT Bates and Oak Ridge National Lab Dalesio, Leo `Bob`
<2007>
