Till Straumann wrote:
Hi.
Let me first say that I'm not sure
'tech-talk' is the right forum to
address with this question which is
rather specific about the mvme5500 RTEMS
BSP and related software
Excuse me, but this is NOT specific
about the RTEMS-mvme5500 BSP. This is
a general question regarding how to load the
RTEMS/BSP/CEXP. It could be for any RTEMS
BSP that uses CEXP. Is'nt that "INIT" used by cexp ?
I think it's a good question to ask in EPICS as most
RTEMS users already know the how-to.
but has nothing
to do with EPICS.
Actaully I would strongly encourage Haoli Shi to
send more questions regarding EPICS3.14.9
to this tech-talk because I did not get a chance to
test the EPICS3.14.9 yet.
Also I would like to know which version of RTEMS Haoli used.
I remember that there were so many bugs in pre RTEMS4.7.0,
which were traced down to the powerPC shared files in the operating
system, but they were not due to the RTEMS-mvme5500 BSP.
Kate
åæç wrote:
hi, there is an error about downloading the st.cmd(OS is RTEMS). in theNVRAM
configuration, I fill the "Command Line Parameters" with
"INIT=/home/shl/psApp/iocBoot/iocmvme5500/power_supply.cmd",but something
wrong appears as follows:
Till Straumann, Stanford/SLAC/SSRL 2002
See LICENSE file for licensing info
Trying to synchronize NTP...OK
Loading as 'shl' from '192.168.20.162' using RSH
Trying symfile 'BUILTIN', system script '/tmp/rshcpya00001'
Type 'cexpsh.help()' for help (no quotes)
Trying user script '/home/shl/psApp/iocBoot/iocmvme5500/power_supply.cmd':
Change Dir to '/home/shl/psApp/iocBoot/iocmvme5500/'
'power_supply.cmd':
opening script file: No such file or directory
Cexp>
why can't it find my .cmd file? (the file indeed lies in the directory,my
TFTP path is /home/shl/tftpboot, and my NFS shared directory is
/home/shl/psApp/iocBoot/iocmvme5500/, but here I use the absolute path)
It seems you use RSH for downloading the
operating system. There is no RSH support
however for downloading other pieces such
as scripts or loadable objects etc.
You must use TFTP or (more convenient) NFS.
The path to the '.cmd' file must contain
information about
a) the remote file-system type (TFTP vs. NFS)
b) the server
c) the remote path
E.g., you could say
INIT=/TFTP/123.4.56.8/psApp/iocBoot/iocmvme5500/power_supply.cmd
or
INIT=nfsserver:/home/shl:psApp/iocBoot/iocmvme5500/power_supply.cmd
another question, in the NVRAM configuration, one can pass a parameter to
application by filling "Command Line Parameters" with "NAME=value". if I won't
pass a parameter, how can I cancel the parameter?
You just leave 'command line parameters'
empty or let 'INIT=<path>' be the only
<NAME>=<value> pair...
HTH
-- Till
thanks a lot!
best regards
Haoli Shi
- Re: .cmd file downloading problem Êêñot;
Proposed change in asyn interruptCallback APIs Mark Rivers
Re: Proposed change in asyn interruptCallback APIs Andrew Johnson
<2007>
Re: .cmd file downloading problem Till Straumann
<2007>
ANJ, 10 Nov 2011 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
