1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: base3.14.9 compile error under uC5282-RTEMS
To: <[email protected]>
Date: Fri, 9 Feb 2007 17:23:57 +0900
Hi All,
I found error messages when the base-3.14.9 IOC compile.
Dose anyone have a proposal for solve this errors?
/usr/local/rtems/rtems-4.7/bin/m68k-rtems4.7-gcc --pipe -B/usr/local/rtems/rtems-4.7/m68k-rtems4.7/uC5282/lib/ -specs bsp_specs -qrtems   -fasm -c   -m528x               -DUNIX    -ansi  -O4 -g -g  -Wall      -DMY_DO_BOOTP=NULL     -DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=aps.anl.gov -DRTEMS_NETWORK_CONFIG_DNS_DOMAINNAME=aps.anl.gov  -I. -I.. -I../../../../include/os/RTEMS -I../../../../include         ../rtems_init.c
../rtems_init.c:40:19: error: iocsh.h: No such file or directory
../rtems_init.c: In function 'initialize_local_filesystem':
../rtems_init.c:151: warning: implicit declaration of function 'open'
../rtems_init.c: In function 'initialize_remote_filesystem':
../rtems_init.c:192: warning: implicit declaration of function 'rpcUdpInit'
../rtems_init.c:193: warning: implicit declaration of function 'nfsInit'
../rtems_init.c:248: warning: implicit declaration of function 'nfsMount'
../rtems_init.c: At top level:
../rtems_init.c:305: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'netStatArg0'
../rtems_init.c:306: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
../rtems_init.c:307: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'netStatFuncDef'
../rtems_init.c:308: warning: type defaults to 'int' in declaration of 'iocshArgBuf'
../rtems_init.c:308: error: expected ';', ',' or ')' before '*' token
../rtems_init.c:313: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'stackCheckFuncDef'
../rtems_init.c:314: warning: type defaults to 'int' in declaration of 'iocshArgBuf'
../rtems_init.c:314: error: expected ';', ',' or ')' before '*' token
../rtems_init.c:319: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'heapSpaceFuncDef'
../rtems_init.c:320: warning: type defaults to 'int' in declaration of 'iocshArgBuf'
../rtems_init.c:320: error: expected ';', ',' or ')' before '*' token
../rtems_init.c:335: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nfsMountArg0'
../rtems_init.c:336: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nfsMountArg1'
../rtems_init.c:337: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nfsMountArg2'
../rtems_init.c:338: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
../rtems_init.c:340: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'nfsMountFuncDef'
../rtems_init.c:341: warning: type defaults to 'int' in declaration of 'iocshArgBuf'
../rtems_init.c:341: error: expected ';', ',' or ')' before '*' token
../rtems_init.c: In function 'iocshRegisterRTEMS':
../rtems_init.c:362: warning: implicit declaration of function 'iocshRegister'
../rtems_init.c:362: error: 'netStatFuncDef' undeclared (first use in this function)
../rtems_init.c:362: error: (Each undeclared identifier is reported only once
../rtems_init.c:362: error: for each function it appears in.)
../rtems_init.c:362: error: 'netStatCallFunc' undeclared (first use in this function)
../rtems_init.c:363: error: 'stackCheckFuncDef' undeclared (first use in this function)
../rtems_init.c:363: error: 'stackCheckCallFunc' undeclared (first use in this function)
../rtems_init.c:364: error: 'heapSpaceFuncDef' undeclared (first use in this function)
../rtems_init.c:364: error: 'heapSpaceCallFunc' undeclared (first use in this function)
../rtems_init.c:366: error: 'nfsMountFuncDef' undeclared (first use in this function)
../rtems_init.c:366: error: 'nfsMountCallFunc' undeclared (first use in this function)
../rtems_init.c: In function 'initConsole':
../rtems_init.c:378: warning: implicit declaration of function 'fileno'
../rtems_init.c: In function 'Init':
../rtems_init.c:535: warning: implicit declaration of function 'tzset'
../rtems_init.c:545: warning: implicit declaration of function 'main'
make[4]: *** [rtems_init.o] error 1
make[4]: ³ª°¨ `/usr/local/epics/base-3.14.9/src/RTEMS/base/O.RTEMS-uC5282' directory
make[3]: *** [install.RTEMS-uC5282] error 2
make[3]: ³ª°¨ `/usr/local/epics/base-3.14.9/src/RTEMS/base' directory
make[2]: *** [base.install] error 2
make[2]: ³ª°¨ `/usr/local/epics/base-3.14.9/src/RTEMS' directory®
make[1]: *** [RTEMS.install] error 2
make[1]: ³ª°¨ `/usr/local/epics/base-3.14.9/src' directory
make: *** [src.install]  error 2
[root@localhost base-3.14.9]#
Kiman Ha,
Pohang Accelator Labaratory
Re: base3.14.9 compile error under uC5282-RTEMS Janet Anderson
Re: base3.14.9 compile error under uC5282-RTEMS Till Straumann
Prev: Base R3.14.9 Released Andrew Johnson
Next: CAC: Ignored conn resp to conn chan CID=0 SID=4180934912? Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  <20072008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: base3.14.9 compile error under uC5282-RTEMS Janet Anderson
ANJ, 10 Nov 2011 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
