1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Support for Strings in database records....
To: David Dudley <[email protected]>
Cc: [email protected]
Date: Mon, 06 Nov 2006 12:07:28 -0600
David,
If 40 characters is enough, use a stringin record (the device support could fetch the latest message). If you need more than 40 characters, use a waveform record with type = char.
Having fun yet?
Ned
David Dudley wrote:
While I'm working on coming up with definitions for all these things...
There are items in the GE Multilin relays that are 'strings' that can be read by my driver. Is there any way to make the string available to a DB record, such that if I get an alarm condition (which is what the strings are), I can display the string in the display somehow?
David
BEGIN:VCARD
VERSION:2.1
X-GWTYPE:USER
FN:David Dudley
TEL;WORK:880-3740
ORG:;MIS
TEL;PREF;FAX:880-3741
EMAIL;WORK;PREF;NGW:[email protected]
N:Dudley;David
END:VCARD
Support for Strings in database records.... David Dudley
Prev: Support for Strings in database records.... David Dudley
Next: Re: AAI/AAO database information Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Support for Strings in database records.... David Dudley
