Almost got the question entirely answered. Just one more thing: Once the initialize routine is executed, can additional records be added? For instance, can an additional I/O item by defined? I'm not giving access to change addresses, but can I also infer that you can't add or delete any? You can't run dbLoadRecords() after iocInit(), so you can't load any new records after initialization, and there is no infrastructure present to allow records to be deleted at runtime. Your "I/O item" would usually map to a record, so you are correct that nothing can be added or deleted after that dset->init(1) call. If you actually want to be able to do something like that you can do it by implementing the Extended Device Support and loading a bunch of 'spare' records; when you need one you set its DTYP and INP/OUT field to the new Modbus address you want to talk to. You can't rename the record at runtime though, so this is not a perfect solution. - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
