For those of you who use Matlab with the 'MCA' extension for ChannelAccess connectivity, there's a new version. Most important are improvements to the timeout handling in 'mcaput', which is a put-callback in most cases, and fewer (actually none so far) crashes on exiting Matlab. More in the release notes copied below. The Extensions/Clients link from the APS web page will direct you to http://ics-web1.sns.ornl.gov/mca.html which hasn't been updated, so you'll have to go directly to http://ics-web1.sns.ornl.gov/~kasemir/mca/index.html to get the latest. I'm sorry to have missed Halloween by a day, but here it is the frightening news: When using ca-put-callback, then waiting for the callback, [Matlab: mcaput(pv_handle, value); ] and then closing the channel, [Matlab: mcaclose(pv_handle); ] I managed to crash IOCs. You should be able to do something similar with other clients that support put-callback. What can happen: 1) On the IOC, the 'put' executes. 2) write_notify_reply() starts, informs the client that the put-callback completed. 3) The client closes the connection, which invokes destroy_client() on the IOC, which deletes the client's "blockSem". 3) write_notify_reply crashes in its final epicsEventSignal ( pClient->blockSem ); You have to get the timing 'just right', and it helps to have an IOC which uses task priorities (vxWorks, Mac OSX, but by default not Linux), since otherwise the thread which runs 'destroy_client' isn't as likely to jump in just before the write_notify_reply() task runs epicsEventSignal(). A possible fix, although I'm can't be 100% sure that this causes new problems, is to change the end of write_notify_reply in base/src/rsrv/ camessage.c like this: /* wait with this unlock... SEND_UNLOCK ( pClient ); */ /* * wakeup the TCP thread if it is waiting for a cb to complete */ epicsEventSignal ( pClient->blockSem ); /* ... until we're really done: */ SEND_UNLOCK ( pClient ); } I saw this with R3.14.8.2, but I think at least back to R3.13.7 all versions of rsrv/camessage.c have a write_notify_reply() routine which releases the pClient lock, and then uses pClient->blockSem. -Kay From the MCA RELEASE_NOTES file: - Found one reason for the occasional crash-on-exit: In mca_cleanup, the 'iterator' used the node that was just deleted to get the 'next' node. - MCAPUT changes: It mostly uses a CA put-callback, which is good, because in Matlab scripts you often want to be assured that the 'put' finished before you move on. Issue 1: When used with arrays of PVs and scalar values to put like this: mcaput([pv1 pv2 pv3 ...], [scalar1 scalar2 scalar3 ...]) ... it would silently _not_ use put callback. Now the online help tells you so. Issue 2: MCAPUT always simply waited for the 'put' timeout. With the default 'put' timeout of 0.01 secs, it would often return 0 = "put didn't succeed" because it didn't wait long enough. Worse: It would actually return the status of the last callback, which might be the 'OK' from a previous caput, not the yet-to-arrive 'not OK' from the ongoing caput. With a 'put' timeout of 10 secs, it would always wait 10 seconds, even if the put callback already arrived 'OK' after e.g. 0.02 secs. Now the 'put' timeout is the max. wait time, but mcaput() will otherwise return as soon as the 'put' callback arrives. Also changed the default 'put' timeout to 10 seconds, in fact all timeouts now default to 10 seconds. - MCAPUT didn't give any error when writing strings to non-string PVs and vice versa. - Made the "No channel exists for this handle." error messages more specific. The main reason for getting this error is timing. Due to irreproducible circumstances, MCAOPEN will sometimes fail to connect within the default timeout. When MCAOPEN is called interactively, it will print a warning message and return a 0 handle. When invoked from inside a script, however, Matlab does not show this warning message, and subsequent use of the 0 handle will then result in this type of error. - The default search timeout was increased from 1 to 10 seconds to make this error less likely. (You can still change it via MCATIMEOUT). - Scripts that re-use the same PV, but don't want to bother with elaborate bookkeeping of open connections, might consider omitting the MCACLOSE calls, and use MCACHECKOPEN in place of every MCAOPEN call. This keeps all connections open and thus avoids re-connect timeouts. Final cleanup can be done via MCAEXIT. - Changed PV hash to template. - Most messages are now more specific, displaying the invoked method and the affected PV name. - Use PVNAME_SZ from base instead of yet another #define. - No more compiler warnings with g++ 4.0 and '-Wall'. - monitor for 'STRING' PVs didn't update the alarm status/severity. - added a mutex for the monitor cache, since both the monitor callback and matlab access it concurrently. - Arranged files in subdirectories. - Added unit tests. - Replaced ChannelAccess.cpp by inlines, no more IsInitialized() checks needed because that's automatic. - Reviewed all the online help, fixed some inconsistencies. Example: MCAINFO and MCASTATE were wrong. Since closed channels are simply gone, they don't show up in the mcastate or mcainfo lists at all, so they also don't show up as 'closed'. - MCACHECK is now the same as MCASTATE. - MCATIME used to return a Matlab datenum for the UTC time zone, and since Matlab lacks timezone support, it was very hard to convert that to 'local' time. Now MCATIME returns 'local' time.
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
