I noticed that the ezca library does not recognize ENUM as a valid data type. One can work around that by telling it to use a SHORT instead. If Would it help to use string data for doing I/O to DBF_ENUM fields? That way you don't need to know the exact ENUM definition (which could change at runtime even for mbbx.VAL fields); your code just uses the strings for the states that you need to use, and the IOC does the necessary conversions automatically. Just an idea, - Andrew -- There is considerable overlap between the intelligence of the smartest bears and the dumbest tourists. -- Yosemite National Park Ranger
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
