Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Who can help with dbLoadRecords()?
To: tech talk <tech-talk@aps.anl.gov>
Date: Mon, 01 May 2006 09:14:18 -0400
Good morning All,
	Any of you use dbLoadRecords( char * dbfile, char *
substitutions) or dbLoadTemplate().
	It's fine but I have another question :) Both functions read
file. I wouldn't catch your attention why I need something because it is
another area of distributed control system. Let say - I need function
	dbLoadRecordsNew( char * records, char * substitutions), where
records is usual db file.
	I looked into code and was very unhappy. dbLoadRecords comes to
dbReadDatabase( ... char * filename ...). That was written so far ... on
yacc (???). Basically, code hasn't comments and isn't self-documented.
Application Development doesn't give information too. I couldn't find
function like dbLoadRecordsNew. Is it correct?
	I thought a little and decided that way to write simple
dbLoadSingleRecord( char * record) function can be easier (then
understand dbReadDatabase() )
	I suppose that should be like
1. There is global variable DBBASE *pdbase that is root Epics DB.
(Manual writes that IOC can have some DBs ... = some pdbase. Is it
correct?)
So first is allocation DB root dbAllocBase()
2. Each record has entry in pdbase.
Call DBENTRY * dbAllocEntry(DBBASE *pdbase). That allocates memory for
entry (!= for record) (?) and link into root.
3. Allocate memory for record. Call malloc with according record?
4. Fill record structure
And IOCInit()
Has anybody knowledge? Can he help me a little?
Thanks, Andrei.
Re: Who can help with dbLoadRecords()? Benjamin Franksen
Prev: Re: asyn and Canberra TCA 2016 Tim Mooney
Next: Digitizer needed for LCLS Steve Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: SNS reaches CD4 milestone!! Gurd, David P.
Next: Re: Who can help with dbLoadRecords()? Benjamin Franksen
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
