Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: RE: streamDevice/Asyn Error: Businterface not found
To: "Porter, Rodney R." <rporter@anl.gov>, <tech-talk@aps.anl.gov>, "Dirk Zimoch" <dirk.zimoch@psi.ch>
Date: Tue, 18 Apr 2006 14:14:08 -0500
Rodney,
asyn autoconnect ports will do exactly as you observe, they will show as disconnected until the first I/O operation, or other operation (such as setting trace mask) that wakes up the port thread.  This is not a sign of a problem, it is normal (if a bit confusing).
I don't know why streamDevice is giving a connection error.
By coincidence I am working on some changes that will fix this behavior, so that that if pasynmanager->connectDevice is called for a port with autoConnect=1 and isConnected=0, then asynManager will queue a request to call pasynCommon->connect.  That way devices will show as connected even before any I/O or setting of trace masks has happened.  That should make things less confusing.  I got this code written before asyn 4.5 was released, but it needs more testing.  It should be included in 4.6 if it works OK.
Sent: Tuesday, April 18, 2006 2:04 PM
To: tech-talk@aps.anl.gov; Dirk Zimoch
Subject: streamDevice/Asyn Error: Businterface not found
I am running EPICS 3.14.8.2, tornado 2.2, asyn 4.5, streamDevice 2.0 on mvme167 and ppc2304 CPUs with a serial port server.  I am able to connect to the serial devices with the generic serial record, but streamDevice gives me a connection error.  asynReport() shows the port disconnected until I connect with the generic serial record or turn on the trace masks.  Am I missing something in the initialization, or is there a problem with the code.
Rodney Porter
Sr. Scientific Programmer
Data Aquisition & Detector Systems
Intense Pulsed Neutron Source
9700 So. Cass Ave
Argonne, IL  60439 USA
Ph. (630) 252-7151
E-mail: rporter@anl.gov
IPNS website: www.pns.anl.gov
Most of boot output follows:
____________________________________________________________________________
dbLoadDatabase("$(TOP)/dbd/ancVx.dbd")
interrupt:
ei0: reset
value = 0 = 0x0
ancVx_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
# Disable Logging
iocLogDisable = 1
iocLogDisable = 0x41e738: value = 1 = 0x1
# Asyn Configuration.
drvAsynSerialPortConfigure("L0","/tyCo/1",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L7","192.168.1.251:2007",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L8","192.168.1.251:2108",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L9","192.168.1.251:2009",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L10","192.168.1.251:2010",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L11","192.168.1.251:2011",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L12","192.168.1.251:2012",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L13","192.168.1.251:2013",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L14","192.168.1.251:2014",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L15","192.168.1.251:2015",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L16","192.168.1.251:2016",0,0,0)
value = 0 = 0x0
# StreamDevice Configuration.
epicsEnvSet("STREAM_PROTOCOL_PATH", "$(TOP)/protocols")
value = 0 = 0x0
# Load EPICS Records
# Uncomment Records and change macro substitutions according to your application
dbLoadRecords("$(TOP)/db/event.db","INST=porter,NN=0,MM=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/runTime.db","INST=porter,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/lksh.db","INST=porter,NN=0,PORT=L8")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/lksh.db","INST=porter,NN=1,PORT=L0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/porterMotor.db")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/posChanger.db","INST=porter,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev2.db","INST=porter,MDEV=huber,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev3.db","INST=porter,MDEV=mdev,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev6.db","INST=porter,MDEV=xyz,NN=0")
value = 0 = 0x0
dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=porter:sr:")
value = 0 = 0x0
dbLoadRecords("$(ASYN)/db/asynRecord.db", "P=porter,R=asyn,PORT=L8,ADDR=0,OMAX=0,IMAX=0")
value = 0 = 0x0
cd startup
value = 0 = 0x0
oms58Setup(6, 0x3000, 190, 5, 10)
value = 0 = 0x0
iocInit
Starting iocInit
### EPICS IOC CORE built on Mar 30 2006
### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
reboot_restore: entry for file 'pos.sav'
reboot_restore (v4.7): entry for file 'pos.sav'
reboot_restore: Found filename 'pos.sav' in restoreFileList.
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/pos.sav' at initHookState 5 ***
../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEreboot_restore: done with file 'pos.sav'
reboot_restore: entry for file 'set.sav'
reboot_restore (v4.7): entry for file 'set.sav'
reboot_restore: Found filename 'set.sav' in restoreFileList.
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/set.sav' at initHookState 5 ***
../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEreboot_restore: done with file 'set.sav'
Businterface 'L8' not found for 'porter:lksh_0:idnstrg'
porter:lksh_0:idnstrg: Can't attach to bus L8 -1
porter:lksh_0:idnstrg: streamInitRecord failed
Businterface 'L0' not found for 'porter:lksh_1:idnstrg'
porter:lksh_1:idnstrg: Can't attach to bus L0 -1
porter:lksh_1:idnstrg: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:atype'
porter:ls330_0:atype: Can't attach to bus L8 -1
porter:ls330_0:atype: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:btype'
porter:ls330_0:btype: Can't attach to bus L8 -1
porter:ls330_0:btype: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:cuid'
porter:ls330_0:cuid: Can't attach to bus L8 -1
porter:ls330_0:cuid: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:atype'
porter:ls330_1:atype: Can't attach to bus L0 -1
porter:ls330_1:atype: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:btype'
porter:ls330_1:btype: Can't attach to bus L0 -1
porter:ls330_1:btype: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:cuid'
porter:ls330_1:cuid: Can't attach to bus L0 -1
porter:ls330_1:cuid: streamInitRecord failed
Businterface 'L8' not found for 'porter:lksh_0:rst'
porter:lksh_0:rst: Can't attach to bus L8 -1
porter:lksh_0:rst: streamInitRecord failed
Businterface 'L0' not found for 'porter:lksh_1:rst'
porter:lksh_1:rst: Can't attach to bus L0 -1
porter:lksh_1:rst: streamInitRecord failed
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/set.sav' at initHookState 6 ***
iocInit: All initialization complete
value = 0 = 0x0
# Configure autoSave for EPICS autoSaveRestore. (task named "save_restore")
# save positions every five seconds
create_monitor_set("pos.req",5,"INST=porter")
value = 0 = 0x0
# save other things every thirty seconds
create_monitor_set("set.req",30,"INST=porter")
value = 0 = 0x0
Done executing startup script /net/iocappsDev/rporter/R3.14.8/ioc/Anc/iocBoot/iocporter-172/st.cmd
iocporter-172> ../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEporter:lksh_0:idnstrg: Record not initialised correctly
porter:lksh_1:idnstrg: Record not initialised correctly
Prev: streamDevice/Asyn Error: Businterface not found Porter, Rodney R.
Next: Problems with files in seq-2-0-11/configure Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: streamDevice/Asyn Error: Businterface not found Dirk Zimoch
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
