1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: streamDevice/Asyn Error: Businterface not found
To: "Porter, Rodney R." <[email protected]>
Cc: [email protected]
Date: Wed, 19 Apr 2006 10:52:54 +0200
This looks as if StreamDevice does not know about asyn.
Try: dbior "stream"
Does it report someting like this?
Driver: stream
  StreamDevice 2.0 built Apr 19 2006 09:25:46
  registered bus interfaces:
    DebugInterface
    AsynDriverInterface
If AsynDriverInterface is not listed, have you accidentally commented out the bus interface in CONFIG_STREAM?
Unfortunately, with asyn 4-5, you still have to specify ASYN_VERS=4-3 in
CONFIG_STREAM (I will fix that later).
Do you load the munched library? On vxWorks, this is required to run the C++ constructors which register the bus interfaces and other things.
Dirk
Porter, Rodney R. wrote:
I am running EPICS 3.14.8.2, tornado 2.2, asyn 4.5, streamDevice 2.0 on mvme167 and ppc2304 CPUs with a serial port server. I am able to connect to the serial devices with the generic serial record, but streamDevice gives me a connection error. asynReport() shows the port disconnected until I connect with the generic serial record or turn on the trace masks. Am I missing something in the initialization, or is there a problem with the code.
Rodney Porter
Sr. Scientific Programmer
Data Aquisition & Detector Systems
Intense Pulsed Neutron Source
Argonne National Laboratory
9700 So. Cass Ave
Argonne, IL 60439 USA
Ph. (630) 252-7151
E-mail: [email protected] <mailto:[email protected]>
IPNS website: www.pns.anl.gov <http://www.pns.anl.gov>
Most of boot output follows:
____________________________________________________________________________
dbLoadDatabase("$(TOP)/dbd/ancVx.dbd")
interrupt:
ei0: reset
value = 0 = 0x0
ancVx_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
# Disable Logging
iocLogDisable = 1
iocLogDisable = 0x41e738: value = 1 = 0x1
# Asyn Configuration.
drvAsynSerialPortConfigure("L0","/tyCo/1",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L7","192.168.1.251:2007",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L8","192.168.1.251:2108",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L9","192.168.1.251:2009",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L10","192.168.1.251:2010",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L11","192.168.1.251:2011",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L12","192.168.1.251:2012",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L13","192.168.1.251:2013",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L14","192.168.1.251:2014",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L15","192.168.1.251:2015",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L16","192.168.1.251:2016",0,0,0)
value = 0 = 0x0
# StreamDevice Configuration.
epicsEnvSet("STREAM_PROTOCOL_PATH", "$(TOP)/protocols")
value = 0 = 0x0
# Load EPICS Records
# Uncomment Records and change macro substitutions according to your application
dbLoadRecords("$(TOP)/db/event.db","INST=porter,NN=0,MM=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/runTime.db","INST=porter,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/lksh.db","INST=porter,NN=0,PORT=L8")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/lksh.db","INST=porter,NN=1,PORT=L0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/porterMotor.db")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/posChanger.db","INST=porter,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev2.db","INST=porter,MDEV=huber,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev3.db","INST=porter,MDEV=mdev,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev6.db","INST=porter,MDEV=xyz,NN=0")
value = 0 = 0x0
dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=porter:sr:")
value = 0 = 0x0
dbLoadRecords("$(ASYN)/db/asynRecord.db", "P=porter,R=asyn,PORT=L8,ADDR=0,OMAX=0,IMAX=0")
value = 0 = 0x0
cd startup
value = 0 = 0x0
oms58Setup(6, 0x3000, 190, 5, 10)
value = 0 = 0x0
iocInit
Starting iocInit
### EPICS IOC CORE built on Mar 30 2006
### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
reboot_restore: entry for file 'pos.sav'
reboot_restore (v4.7): entry for file 'pos.sav'
reboot_restore: Found filename 'pos.sav' in restoreFileList.
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/pos.sav' at initHookState 5 ***
../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEreboot_restore: done with file 'pos.sav'
reboot_restore: entry for file 'set.sav'
reboot_restore (v4.7): entry for file 'set.sav'
reboot_restore: Found filename 'set.sav' in restoreFileList.
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/set.sav' at initHookState 5 ***
../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEreboot_restore: done with file 'set.sav'
Businterface 'L8' not found for 'porter:lksh_0:idnstrg'
porter:lksh_0:idnstrg: Can't attach to bus L8 -1
porter:lksh_0:idnstrg: streamInitRecord failed
Businterface 'L0' not found for 'porter:lksh_1:idnstrg'
porter:lksh_1:idnstrg: Can't attach to bus L0 -1
porter:lksh_1:idnstrg: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:atype'
porter:ls330_0:atype: Can't attach to bus L8 -1
porter:ls330_0:atype: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:btype'
porter:ls330_0:btype: Can't attach to bus L8 -1
porter:ls330_0:btype: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:cuid'
porter:ls330_0:cuid: Can't attach to bus L8 -1
porter:ls330_0:cuid: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:atype'
porter:ls330_1:atype: Can't attach to bus L0 -1
porter:ls330_1:atype: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:btype'
porter:ls330_1:btype: Can't attach to bus L0 -1
porter:ls330_1:btype: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:cuid'
porter:ls330_1:cuid: Can't attach to bus L0 -1
porter:ls330_1:cuid: streamInitRecord failed
Businterface 'L8' not found for 'porter:lksh_0:rst'
porter:lksh_0:rst: Can't attach to bus L8 -1
porter:lksh_0:rst: streamInitRecord failed
Businterface 'L0' not found for 'porter:lksh_1:rst'
porter:lksh_1:rst: Can't attach to bus L0 -1
porter:lksh_1:rst: streamInitRecord failed
*** restoring from '/net/iocappsDev/rporter/inst/autosave/porter/set.sav' at initHookState 6 ***
iocInit: All initialization complete
value = 0 = 0x0
# Configure autoSave for EPICS autoSaveRestore. (task named "save_restore")
# save positions every five seconds
create_monitor_set("pos.req",5,"INST=porter")
value = 0 = 0x0
# save other things every thirty seconds
create_monitor_set("set.req",30,"INST=porter")
value = 0 = 0x0
Done executing startup script /net/iocappsDev/rporter/R3.14.8/ioc/Anc/iocBoot/iocporter-172/st.cmd
iocporter-172> ../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96): [0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEporter:lksh_0:idnstrg: Record not initialised correctly
porter:lksh_1:idnstrg: Record not initialised correctly
-- Dr. Dirk Zimoch Swiss Light Source Paul Scherrer Institut Computing and Controls phone +41 56 310 5182 fax +41 56 310 4413
streamDevice/Asyn Error: Businterface not found Porter, Rodney R.
Prev: Allen Bradely ControlLogix Version Control ? John Dobbins
Next: RE: Allen Bradely ControlLogix Version Control ? Tang, Johnny Y.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: streamDevice/Asyn Error: Businterface not found Porter, Rodney R.
Next: RE: streamDevice/Asyn Error: Businterface not found Mark Rivers
