If I recall correctly the embedding of hex or octal bytes was introduced
in release 2.0. Hopefully you have a more recent version Ian.
Also keep in mind that it is always possible to create your own protocol
framing routines and have them called from getFrame and putFrame. To do
that your special framing routines must be registered with
drvAsciiSetTxFunc and drvAsciiSetRxFunc prior to iocInit.
Al
-----Original Message-----
Sent: Friday, March 03, 2006 7:17 AM
To: Ian A Smith; [email protected]
Subject: RE: drvAscii codes
Ian,
The documentation says that what you have should work. I practice, I
have used \x03 and \x02 instead of \003 and \002 for a similar device
and it has worked. Let me know if this fixes your problem.
Rodney Porter
Sr. Scientific Programmer
Data Aquisition & Detector Systems
Intense Pulsed Neutron Source
Argonne National Laboratory
9700 So. Cass Ave
Argonne, IL 60439 USA
Ph. (630) 252-7151
E-mail: [email protected]
IPNS website: www.pns.anl.gov
Sent: Friday, March 03, 2006 4:10 AM
To: [email protected]
Subject: drvAscii codes
I'm trying to get epics to talk to an (awkward) piece of equipment. It
requires: "[stx]command[etx][cr][lf]", where of course, [stx] and [etx]
are ascii 2 and 3.
I've succeeded in puting the [etx] on the end of lines but I get the
literal string "\002" instead of [stx] at the start, so I'm looking for
help!
The record which successfully puts [etx] in line termination is:
record(stringout,"scu2CCS:shutter:coms:txCmd") {
field(DESC,"string output record")
field(SCAN,"Passive")
field(PINI,"YES")
field(PHAS,"0")
field(EVNT,"0")
field(DTYP,"Ascii SIO")
field(DISV,"1")
field(SDIS,"0.000000000000000e+00")
field(DISS,"NO_ALARM")
field(PRIO,"LOW")
field(FLNK,"0.000000000000000e+00")
field(VAL,"\003\r\n")
field(DOL,"\003\r\n")
field(OMSL,"closed_loop")
field(OUT,"@/pty/shutterM <writeCmt %s>")
field(SIOL,"0.000000000000000e+00")
field(SIML,"0.000000000000000e+00")
field(SIMS,"NO_ALARM")
field(IVOA,"Continue normally")
field(IVOV,"")
and the record which fails to put [stx] in the command line is:
record(stringin,"scu2CCS:shutter:test") {
field(DESC,"string input record")
field(SCAN,"10 second")
field(PINI,"NO")
field(PHAS,"0")
field(EVNT,"0")
field(DISV,"1")
field(PRIO,"LOW")
field(VAL,"string")
field(INP,"@/pty/shutterM <\002SUI><%s>")
TIA
Ian A Smith Telephone: +44 (0) 131 668 8255
Royal Observatory Fax: +44 (0) 131 668 8314
Blackford Hill Web: http://www.roe.ac.uk/
Edinburgh
EH9 3HJ
UK
RE: drvAscii codes Porter, Rodney R.
RE: Gateway error Jeff Hill
<2006>
Re: drvAscii codes Ian A Smith
calcPerform expressions: 'NOT' operator Andrew Johnson
<2006>
