-----Original Message-----
[mailto:[email protected]]
Sent: Friday, March 03, 2006 4:03
AM
To: [email protected]
Subject: Gateway error
We have been running the new gateway 2.0 on epics
3.14.8.2 for a month or more with good results. It has been stable even
with large transfers.
However last evening a problem occurred with the gateway and
it had to be restarted. Unfortunately the only information I have is the
following gateway log.
Can anyone hazard a guess as to what was going on ?
We are running the gateway on Redhat Enterprise Linux 4.
Also we are running the alarm handler through the gateway
too which I understand from previous Techtalk emails is a bad thing (DBE_VALUE
v DBE_ALARM events subscription conflict) and something we have to address.
Could this have caused the problem?
Feb 27 09:01:02 PV Gateway Version 2.0.0.0 [Jan 9 2006
11:30:43]
EPICS 3.14.8.2 PID=2598 ServerPID=2597
EPICS_CA_ADDR_LIST=172.23.255.255
EPICS_CA_AUTO_ADDR_LIST=NO
EPICS_CA_SERVER_PORT=5064
EPICS_CA_MAX_ARRAY_BYTES=3000000
EPICS_CAS_INTF_ADDR_LIST=172.23.194.129
EPICS_CAS_SERVER_PORT=5064
EPICS_CAS_IGNORE_ADDR_LIST=172.23.194.129
Running as user gate on host serv0013.cs.diamond.ac.uk
Statistics PV prefix is CtoP:serv0013
Feb 28 14:42:43 Warning: Virtual circuit unresponsive 172.23.248.87:5064
Unexpected problem with CA circuit to server "172.23.248.87:5064" was
"No route to host" - disconnecting
Feb 28 14:58:03 !!! Errlog message received (message is
above)
Feb 28 14:58:03 Warning: Virtual circuit disconnect 172.23.248.87:5064
Feb 28 15:36:41 Warning: Virtual circuit unresponsive 172.23.248.60:5064
CAS: TCP socket send to "172.23.198.8:32805" failed because "No
route to host"
Feb 28 15:50:15 !!! Errlog message received (message is
above)
Unexpected problem with CA circuit to server "172.23.248.60:5064" was
Feb 28 15:52:01 !!! Errlog message received (message is
above)
Feb 28 15:52:01 Warning: Virtual circuit disconnect 172.23.248.60:5064
Feb 28 16:15:46 Warning: Virtual circuit unresponsive 172.23.248.109:5064
CAS: TCP socket send to "172.23.198.8:32813" failed because "No
route to host"
Feb 28 16:16:40 !!! Errlog message received (message is
above)
Unexpected problem with CA circuit to server "172.23.248.109:5064"
was "No route to host" - disconnecting
Feb 28 16:31:07 !!! Errlog message received (message is
above)
Feb 28 16:31:07 Warning: Virtual circuit disconnect 172.23.248.109:5064
Mar 01 10:41:06 Warning: Virtual circuit unresponsive 172.23.248.25:5064
Mar 01 10:41:07 Warning: Virtual circuit unresponsive 172.23.248.27:5064
Mar 01 10:41:09 Warning: Virtual circuit unresponsive 172.23.248.83:5064
Mar 01 10:41:11 Warning: Virtual circuit unresponsive 172.23.248.195:5064
Mar 01 10:41:15 Warning: Virtual circuit unresponsive 172.23.248.164:5064
Mar 01 10:41:15 Warning: Virtual circuit unresponsive 172.23.248.24:5064
Mar 01 10:41:16 Warning: Virtual circuit unresponsive 172.23.248.144:5064
Unexpected problem with CA circuit to server "172.23.248.25:5064" was
Mar 01 10:56:27 !!! Errlog message received (message is
above)
Mar 01 10:56:27 Warning: Virtual circuit disconnect 172.23.248.25:5064
Unexpected problem with CA circuit to server "172.23.248.83:5064" was
Mar 01 10:56:29 !!! Errlog message received (message is
above)
Mar 01 10:56:29 Warning: Virtual circuit disconnect 172.23.248.83:5064
CAS: client 172.23.198.11:32812 disconnected because "No route to
host"
Mar 01 10:56:32 !!! Errlog message received (message is
above)
Unexpected problem with CA circuit to server "172.23.248.195:5064"
above)
Mar 01 10:56:32 Warning: Virtual circuit disconnect 172.23.248.195:5064
Unexpected problem with CA circuit to server "172.23.248.164:5064"
Mar 01 10:56:36 !!! Errlog message received (message is
above)
Mar 01 10:56:36 Warning: Virtual circuit disconnect 172.23.248.164:5064
Unexpected problem with CA circuit to server "172.23.248.24:5064" was
above)
Mar 01 10:56:36 Warning: Virtual circuit disconnect 172.23.248.24:5064
Unexpected problem with CA circuit to server "172.23.248.144:5064"
Mar 01 10:56:37 !!! Errlog message received (message is
above)
Mar 01 10:56:37 Warning: Virtual circuit disconnect 172.23.248.144:5064
Unexpected problem with CA circuit to server "172.23.248.27:5064" was
Mar 01 10:56:44 !!! Errlog message received (message is
above)
Mar 01 10:56:44 Warning: Virtual circuit disconnect 172.23.248.27:5064
CAS: client 172.23.200.84:1090 disconnected because "No route to
host"
Mar 01 10:57:00 !!! Errlog message received (message is
above)
Mar 01 16:54:11 Warning: Virtual circuit unresponsive 172.23.248.24:5064
Mar 01 16:54:32 Warning: Virtual circuit unresponsive 172.23.248.27:5064
Mar 01 16:54:40 Warning: Virtual circuit unresponsive 172.23.248.83:5064
"Connection reset by peer" - disconnecting
Mar 01 16:54:54 !!! Errlog message received (message is
above)
Mar 01 16:54:54 Warning: Virtual circuit disconnect 172.23.248.27:5064
Mar 01 16:54:57 Warning: Virtual circuit unresponsive 172.23.248.195:5064
Mar 01 16:54:58 !!! Errlog message received (message is
above)
Mar 01 16:54:58 Warning: Virtual circuit disconnect 172.23.248.24:5064
was "Connection reset by peer" - disconnecting
Mar 01 16:55:18 !!! Errlog message received (message is
above)
Mar 01 16:55:18 Warning: Virtual circuit disconnect 172.23.248.195:5064
Mar 01 16:55:26 !!! Errlog message received (message is
above)
Mar 01 16:55:26 Warning: Virtual circuit disconnect 172.23.248.83:5064
Unexpected problem with CA circuit to server "172.23.252.107:5064"
Mar 01 17:06:40 !!! Errlog message received (message is
above)
Mar 01 17:06:40 Warning: Virtual circuit disconnect 172.23.252.107:5064
Mar 01 17:18:05 !!! Errlog message received (message is
above)
Mar 01 17:18:05 Warning: Virtual circuit disconnect 172.23.248.195:5064
Mar 01 17:20:37 !!! Errlog message received (message is
above)
Mar 01 17:20:37 Warning: Virtual circuit disconnect 172.23.248.195:5064
A call to "assert (item.pList == this)" failed in
../../../../src/cas/generic/st/ioBlocked.cc line 112.
Mar 01 18:30:04 !!! Errlog message received (message is
above)
EPICS Release EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$.
above)
Current time Wed Mar 01 2006 18:30:04.20652000.
above)
Calling epicsThreadSuspendSelf()
above)
Mar 01 19:28:11 PV Gateway Ending (SIGTERM)
Mr P J Leicester
Senior Software Engineer
Diamond Light Source Ltd.
Rutherford Appleton Laboratory
Chilton
Didcot
OX11 0QX
Tel: 01235 778478
