1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: GPIB swap 1014D with 1014
To: "Ned Arnold" <[email protected]>
Cc: "APS tech-talk" <[email protected]>
Date: Thu, 23 Feb 2006 10:26:39 -0600
Thanks Ned!
This occurred to me when I was perusing the manual and Tech talk, two could be used with some kind of addressing.
I can scrounge up some devices to talk (and some cables) to I will test the addressing. We have beam circulating where we hope to use this as a "spare". Next access will be in March.
Thanks again,
Bill Waggoner
STAR
-----Original Message-----
Sent: Wednesday, February 22, 2006 7:27 PM
To: Waggoner, Bill
Cc: APS tech-talk
Subject: Re: GPIB swap 1014D with 1014
Hi Bill,
We also use both the 1014D and 1014.  Although I have not tried it for
several years, I think your evaluation is pretty accurate ... but one
can easily replace a 1014D with two 1014s.
By default:
A16 address for the #L0 card is 0x5000
A16 address for the #L1 card is 0x5200
The 1014D covers both address spaces if the base address is set to
0x5000, thereby servicing #L0 and #L1.
So, if you replace the 101D with two 1014s, you don't even have to
change your databases.
Ned
Waggoner, Bill wrote:
> Greetings from STAR on LI,
> We have three subsystems using NI 1014 type GPIB interfaces.  All of
> these have been running for many years, and all are using 3.12 EPICS.
> One subsystems uses a 1014D, dual port interface. It was brought to my
> attention that we have no spare for this system. I was looking into the
> problems that would arise should we have to swap this with  a 1014 mono
> port interface. We have several spare 1014, and our other option would
> be to buy another 1014D
>  From the code, and the device support, the startup scripts, and the
> state programs we use for  the two types of interfaces I see no real
> differences. The only difference is in the record fields where the dual
> port has two lines #L0 and #L1 in its database.
> Would a swap only involve a database change? What hardware
> considerations are involved?  I have had no previous experience (up to
> 24 hours ago) with GPIB, and have been perusing the manuals, and tech
> talk.  Normally I would just play, but we are now buttoned up with beam
> for this system, and wont have access for weeks.
> Any answers, and suggestions are greatly appreciated.
> Thanks in Advance,
> Bill Waggoner
> STAR
> BNL
> PS Eventually.. next year?  we might upgrade this to EPICS 3.13 or
> 3.14.. but time constraints aren’t going to allow that for this run.
> No virus found in this outgoing message.
> Checked by AVG Free Edition.
> Version: 7.1.375 / Virus Database: 267.15.11/264 - Release Date: 2/17/2006
No virus found in this incoming message.
Prev: It's ok now liushu
Next: EZCA win32 URIOT Didier DAPNIA
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: GPIB swap 1014D with 1014 Ned Arnold
Next: It's ok now liushu
