I need to develop a little application making some epics channel access under WindowsNT. I’m using Borland C++ compilator.
So, I used easy ca library for win32.
I’m just used some ezcaGet(…) and
ezcaPut(…) functions in a very small code.
I linked with ca.dll.
Compilation and linking worked.
But, the ezcaGet(…) function make the
code very unstable and I don’t understand why.
In the following example, ezcaGat(..) works, but when
I leave the main() procedure, the code systematically crashes!!!
int main (int argc, char *argv[])
double d;
ezcaGet(“epic_data1
",ezcaDouble,1,&d);
return 0;
Someone already meet this problem?
Thanks in advance
