Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Ansi compiler switch
From: Michael Abbott <michael.abbott@diamond.ac.uk>
To: tech-talk@aps.anl.gov
Date: Sat, 28 Jan 2006 16:19:19 +0000 (GMT)
I have an Epics 3.14.7 driver where I found myself wanting to use the typeof() primitive: as this doesn't appear to be supported as part of ANSI C++ I found it necessary to defeat the -ansi flag that seems to be set by default in the Epics build environment.
My question is this: what is the "correct" way to defeat this flag? Digging through the make system, I discovered that adding the following two lines to my Makefile does the trick:
	CMPLR=LAX
	CXXCMPLR=LAX
(As I recall it, all that matters is that the RHS is not the string STRICT.)
I was wondering *why* this flag is set, but thinking about it I guess the point is that Epics is intended to be thoroughly cross-platform these days. My driver most definitely isn't, so I'm happy to lose the flag, but I'd like to know that I'm not abusing the makefile.
Re: Ansi compiler switch Emmanuel Mayssat
Prev: Re: enhanced seq record Benjamin Franksen
Next: Re: enhanced seq record Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: enhanced seq record Brian McAllister
Next: Re: Ansi compiler switch Emmanuel Mayssat
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
