Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Timestamp record? UPTIME
To: Ralph Lange <Ralph.Lange@bessy.de>
Cc: Steven Banks <steven.banks@synchrotron.vic.gov.au>, <tech-talk@aps.anl.gov>
Date: Mon, 23 Jan 2006 11:39:24 +0100 (CET)
Hi Ralph,
	I have installed the PC monitoring project under the web server in
SLS/PSI. The tar.gz  file could be found under
http://epics.web.psi.ch/software/pcmon/PC-MONITOR-EPICS3.14.7.tar.gz
PC-MONITOR-EPICS3.14.7/README file explains how to deal with that project.
Best Regards
Mirek
On Fri, 20 Jan 2006, Ralph Lange wrote:
> Hi Steven, hi Marek,
> would you be so kind to add this module with contact and download info
> to the soft support database on the EPICS web server?
> After Mirek sent such an impressive screen shot I'm sure there's a
> broader interest in using that system....
> Thanks a lot!
> Ralph
> Miroslaw Dach wrote:
> >Dear All,
> >	Here in SLS/PSI we use for last 8 months the PCs monitoring
> >system which is based on EPICS and Linux.
> >Please find in the attachment the screen dump with all of the monitored
> >parameters.
> >Best Regards
> >Mirek
> >>Title: Message
> >>At the Australian Synchrotron we've written a device support routine
> for
> >>our Redhat Linux IOCs which allows various statuses, including the
> >>machine
> >>and IOC uptime, to be monitored via PVs.
> >>If you wish, I can sent you the source code, including a small demo
> >>application.
> >>Dr. Steven M. Banks . Control Systems Engineer
> >>Australian Synchrotron Project
> >>Major Projects Victoria
> >>800 Blackburn Road
> >>CLAYTON VIC 3168
> >>tel: +613 8540 4103
> >>fax: +613 8540 4200
> >>mailto:steven.banks@synchrotron.vic.gov.au
> >>http://www.synchrotron.vic.gov.au
          Miroslaw Dach (Miroslaw.Dach@psi.ch) - SLS/Controls Group
                PSI - Paul Scherrer Institut CH-5232 Villigen
Re: Timestamp record? UPTIME Ralph Lange
Prev: RE: ASYN Question Mark Rivers
Next: Agilent 34401A DVM support? Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Prev: Re: Timestamp record? UPTIME Ralph Lange
Next: EPICS Patriarch Succumbs to Stronger Call Ned Arnold
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
