Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: Timestamp record? UPTIME
To: Miroslaw Dach <dach@psi.ch>, Steven Banks <steven.banks@synchrotron.vic.gov.au>
Cc: tech-talk@aps.anl.gov
Date: Fri, 20 Jan 2006 09:41:39 +0100
Hi Steven, hi Marek,
would you be so kind to add this module with contact and download info to the soft support database on the EPICS web server?
After Mirek sent such an impressive screen shot I'm sure there's a broader interest in using that system....
Thanks a lot!
Ralph
Miroslaw Dach wrote:
Dear All,
Here in SLS/PSI we use for last 8 months the PCs monitoring system which is based on EPICS and Linux. Please find in the attachment the screen dump with all of the monitored parameters.
Best Regards
Mirek
Title: Message
At the Australian Synchrotron we've written a device support routine for our Redhat Linux IOCs which allows various statuses, including the machine and IOC uptime, to be monitored via PVs.
If you wish, I can sent you the source code, including a small demo application.
Dr. Steven M. Banks . Control Systems Engineer Australian Synchrotron Project Major Projects Victoria 800 Blackburn Road CLAYTON VIC 3168 tel: +613 8540 4103 fax: +613 8540 4200 mailto:steven.banks@synchrotron.vic.gov.au http://www.synchrotron.vic.gov.au
Re: Timestamp record? UPTIME Miroslaw Dach
RE: Timestamp record? UPTIME Miroslaw Dach
Prev: RE: Timestamp record? UPTIME Miroslaw Dach
Next: Re: Cost effective solution for monitoring a large number of temperatures Bernhard Kuner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Next: Re: Timestamp record? UPTIME Miroslaw Dach
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
