1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: order of DTYP and INP/OUT fields in db-Files and vdct
To: [email protected]
Date: Fri, 09 Dec 2005 07:15:09 -0600
Thomas Birke wrote:
we just found the "feature" again, that in record-sections of db-files, the DTYP field has to be set before the INP or OUT field (at least for INST_IO), it took us an hour or two to track this down.
I didn't search for that in the AppDevGuide and other docs, since I'm afraid (and definitely hope), I'll find that documented, since I found tha last reference to that "feature" on tech-talk back in '99. It was undocumented back then...
Section 6.12 of the latest 3.14 Application Developers Guide contains a subsection 6.12.2 which is titled "definitions" look for
DBF_INLINK, DBF_OUTLINK
In the NOTES it states that DTYP must be defined before the associated INP or OUT field.
I looked and this note appears in the earliest 3.14 version of the appDevGuide.
Re: order of DTYP and INP/OUT fields in db-Files and vdct Thomas Birke
Prev: order of DTYP and INP/OUT fields in db-Files and vdct Thomas Birke
Next: Re: order of DTYP and INP/OUT fields in db-Files and vdct Thomas Birke
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
