1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: order of DTYP and INP/OUT fields in db-Files and vdct
To: [email protected]
Date: Fri, 09 Dec 2005 14:28:47 +0100
Marty Kraimer wrote:
Thomas Birke wrote:
we just found the "feature" again, that in record-sections of db-files, the DTYP field has to be set before the INP or OUT field (at least for INST_IO), it took us an hour or two to track this down.
I didn't search for that in the AppDevGuide and other docs, since I'm afraid (and definitely hope), I'll find that documented, since I found tha last reference to that "feature" on tech-talk back in '99. It was undocumented back then...
Section 6.12 of the latest 3.14 Application Developers Guide contains a subsection 6.12.2 which is titled "definitions" look for
DBF_INLINK, DBF_OUTLINK
In the NOTES it states that DTYP must be defined before the associated INP or OUT field.
I looked and this note appears in the earliest 3.14 version of the appDevGuide.
So at least, it's documented and I may even have read it, but it must have slipped my mind... ;-)
I still suggest to change vdct to behave according to that.
Thomas
______________________________________________________________________
/homas.Birke @ bessy.de
BESSY                                           Tel: +49 30 6392 4934
Albert Einstein StraÃe 15                       Fax: +49 30 6392 4859
12489 Berlin
Germany
order of DTYP and INP/OUT fields in db-Files and vdct Thomas Birke
Re: order of DTYP and INP/OUT fields in db-Files and vdct Marty Kraimer
Prev: Re: order of DTYP and INP/OUT fields in db-Files and vdct Marty Kraimer
Next: Re: order of DTYP and INP/OUT fields in db-Files and vdct Michael Abbott
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
