We have built the 11/07/2005 snapshot of the Channel Archiver with EPICS R3.14.7 . Everything seems to be working until we try to connect to the ArchiveDataServer. Using the java Archive Viewer, the following error appears on the console when trying to connect to ArchiveDataServer.cgi : Fatal error parsing XML: org.xml.sax.SAXParseException: expected Element and the java Archive Viewer gui displays the following error: java.lang.IllegalArgumentException: Couldn't execute the archiver.info request java.io.IOException: org.xml.sax.SAXParseException: expected Element ArchiveDataClient.pl gives a somewhat different error: [dab66@ees101 dab66]% ArchiveDataClient.pl -u $URL -a Archives: not well-formed (invalid token) at line 1, column 0, byte 0 at /usr/ lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi/XML/Parser.pm line 185 Any suggestions would be greatly appreciated. Thanks, Devin ------ Devin Bougie Laboratory for Elementary-Particle Physics [email protected]
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
