1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Waveform soft record
To: [email protected]
Date: Wed, 02 Nov 2005 17:58:10 -0800
I have an ADC record that contains 32 waveforms.
I would like to create 32 waveform records that when addressed will
indeed access the data from the first record.
In other words, I have an ADC with 32 inputs.
The 32 inputs are sampled at the same rate and are therefore
linked/related. I created a record that reads the ADC on-board memory
and populates the ADC record.
This record could be named iocname:ADC:adcID
Now, I would like to create 32 independent waveform records such as
iocname:ADC:adcID:pinNumber that will be a copy of one of the 32
waveform records.
How would you do that ? Does such a soft record already exist?
Emmanuel Mayssat
Lyncean Technologies, Inc.
Palo Alto, CA94306
Cell: 650/793-0626
"See the invisible"
Re: Waveform soft record Steven Hartman
RE: Asyn build under win32 Mark Bennett
Prev: RE: caSnoop build problem Kenneth Evans, Jr.
Next: RE: caSnoop build problem Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: Asyn build under win32 Mark Bennett
Next: Re: Waveform soft record Steven Hartman
