msi is a standard epics extension.
See
http://www.aps.anl.gov/epics/extensions/msi/index.php
J. Lewis Muir wrote:
Hello.
While trying to build synApps 5.1 with EPICS 3.14.7 on Red Hat
Enterprise Linux WS v.3, it looks like it can't find a program called
msi.
Does anyone know what msi is or where to get it?
If I comment out the vxStat and xxx modules in config/MASTER_RELEASE
and config/Makefile it builds successfully.
To build, I did the following:
Edited config/MASTER_RELEASE to match my install locations and to fix
the paths for the modules.
Edited motor/motorApp/Makefile to include the motors I wanted.
Downloaded and extracted the modules allenBradley v2-1, asyn v4-2-1,
ipac v2-8, seq v2-0-10, and genSub v1-6.
Added a configure directory (and files) for genSub since it didn't
have one.
Edited the configure/RELEASE file for all modules to have correct
module paths.
Fixed TEMPLATE_TOP variable in love/configure/RELEASE.
$ cd config
$ make
Here's the actual error message:
mkdir O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[4]: Entering directory
`/opt/synapps-5_1/support/vxStats/vxStatsApp/Db/O.linux-x86'
Inflating database from ../vxStats-template.substitutions using local
rule
msi -S../vxStats-template.substitutions > vxStats-template.db </dev/null
/bin/sh: line 1: msi: command not found
make[4]: *** [../O.Common/vxStats-template.db] Error 127
make[4]: Leaving directory
make[3]: *** [install.linux-x86] Error 2
make[3]: Leaving directory
`/opt/synapps-5_1/support/vxStats/vxStatsApp/Db'
make[2]: *** [Db.install] Error 2make[2]: Leaving directory
`/opt/synapps-5_1/support/vxStats/vxStatsApp'
make[1]: *** [vxStatsApp.install] Error 2
make[1]: Leaving directory `/opt/synapps-5_1/support/vxStats'
make: *** [/opt/synapps-5_1/support/vxStats.install] Error 2
Thanks!
-lewis
- msi command for building synApps 5.1 J. Lewis Muir
Re: msi command for building synApps 5.1 Ralph Lange
Arrays in Start Up Scripts Darrell Nineham
<2005>
Re: msi command for building synApps 5.1 J. Lewis Muir
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
