While trying to build synApps 5.1 with EPICS 3.14.7 on Red Hat Enterprise Linux WS v.3, it looks like it can't find a program called msi. Does anyone know what msi is or where to get it? If I comment out the vxStat and xxx modules in config/MASTER_RELEASE and config/Makefile it builds successfully. To build, I did the following: Edited config/MASTER_RELEASE to match my install locations and to fix the paths for the modules. Edited motor/motorApp/Makefile to include the motors I wanted. Downloaded and extracted the modules allenBradley v2-1, asyn v4-2-1, ipac v2-8, seq v2-0-10, and genSub v1-6. Added a configure directory (and files) for genSub since it didn't have one. Edited the configure/RELEASE file for all modules to have correct module paths. Fixed TEMPLATE_TOP variable in love/configure/RELEASE. $ cd config $ make Here's the actual error message: .... mkdir O.Common make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install make[4]: Entering directory `/opt/synapps-5_1/support/vxStats/vxStatsApp/Db/O.linux-x86' Inflating database from ../vxStats-template.substitutions using local rule msi -S../vxStats-template.substitutions > vxStats-template.db </dev/null /bin/sh: line 1: msi: command not found make[4]: *** [../O.Common/vxStats-template.db] Error 127 make[4]: Leaving directory `/opt/synapps-5_1/support/vxStats/vxStatsApp/Db/O.linux-x86' make[3]: *** [install.linux-x86] Error 2 make[3]: Leaving directory `/opt/synapps-5_1/support/vxStats/vxStatsApp/Db' make[2]: *** [Db.install] Error 2make[2]: Leaving directory `/opt/synapps-5_1/support/vxStats/vxStatsApp' make[1]: *** [vxStatsApp.install] Error 2 make[1]: Leaving directory `/opt/synapps-5_1/support/vxStats' make: *** [/opt/synapps-5_1/support/vxStats.install] Error 2 Thanks! -lewis
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
