1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: errlogXXX functions and behavior
To: "'Liyu, Andrei'" <[email protected]>, <[email protected]>
Date: Mon, 18 Jul 2005 11:11:27 -0600
Hell Andrei,
Thanks for your bug report. I created Mantis Entry 209 to tack this issue.
> hebt-diag-ioc-blm1>log client: lost contact with log server at
> "172.31.72.101:6500" because "S_errno_EPIPE"
> log client: connected to error message log server at "172.31.72.101:6500"
> - I don't see anything in errorLog file!
The log client checks its circuit with the log server only when there is a
message to send. So, in this case, I presume that the log server was
restarted and that the client, trying to communicate over a defunct circuit,
discovered a disconnect. When there is a disconnect all pending messages are
discarded.
> One more time but without "n"
> hebt-diag-ioc-blm1>errlogMessage("Third")
> Thirdvalue = 0 = 0x0
> I see response from errorLog file
> hebt-diag-ioc-blm1.ics.sns.gov: Wed Jul 13 11:38:32 2005 Thirdd+N
This will need to be investigated.
> 3. If I don't use errlogMessage with "\n" all time I see very strange.
> At first, I don't see error message from item 1. At second, I see
> response from errorLog file each time when buffer is full (~1280).
The log server works this way by design - it does not flush its internal
buffer to the file until it sees a '\n'. This behavior is tended to prevent
output from multiple clients (IOCs) from getting mixed together.
Jeff
> -----Original Message-----
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Wednesday, July 13, 2005 9:54 AM
> To: [email protected]
> Subject: errlogXXX functions and behavior
> Hi,
> 1. When I use errlogMessage first time then
> - I see on terminal
> hebt-diag-ioc-blm1>errlogMessage("First+N\n")
> First+N
> value = 0 = 0x0
> 2. Then I type again
> hebt-diag-ioc-blm1>errlogMessage("Second+N\n")
> Second+N
> value = 0 = 0x0
> hebt-diag-ioc-blm1.ics.sns.gov: Wed Jul 13 11:38:02 2005 Second+N
> One more time but without "\n"
> I suppose this is not ioc that errlog server! If I reboot IOC I see the
> same tail from buffer.
> 4. Of course, I don't refuse to see a little smart client for text file.
> Where I can choice message by ioc name, system/subsystem/module name and
> so on. And maybe it will work from buffer ... :-)
> Have a good day, Andrei Liyu
errlogXXX functions and behavior Liyu, Andrei
Prev: RE: iocLogServer change? Allison, Stephanie
Next: JCA2 example code John Faucett
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: errlogXXX functions and behavior Ralph Lange
Next: RE: errlogXXX functions and behavior Liyu, Andrei
