I have downloaded EPICS base 3.14.7 and built it
under the provided 'hpux-parisc' setting of $EPICS_HOST_ARC. All built
fine. I built a test client program that performs a couple channel access
fetches and prints the results. The test program works fine when I build against
our existing EPICS 3.13.2 installation, but there is a problem running with
the newer EPICS version. The program performs the channels access operations
correctly, but the signal value prints are sometimes followed by "epicsThreadOnceOsd epicsMutexLock failed" written to the command shell. I suspect the message is
generated when I close the channel and exit the program. The number of
times the message is written varies from zero to two. More often it is zero, and
only once have I seen two. Can anyone explain to me what this message means, and
what I need to do to correct it?
Chris
Slominski
Thomas Jefferson National Accelerator Facility Phone:(757)
269-6030 Pager: 584-6030
- RE: odd libca message printed Jeff Hill
Unbounded integer types Benjamin Franksen
vmivme7050 Ian A Smith
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
