Hi Kate,
Please provide more info.
For example, maybe your default route was being provided by the network
you disconnected. Try the same experiment but disconnect the other
cable. Does the same thing happen?
Send the output of your routing table:
routeShow
Ernest L. Williams Jr.
SNS Control Systems Group
ORNL
On Fri, 2005-04-15 at 13:27 -0400, Kate Feng wrote:
> Hi,
> There are two network interfaces (N.I.) on my IOC, each attached
> to a different IP address. I thought one could decide which medm
> clients "Channel Accessing" which N.I. by opening two windows.
> Both windows are set with EPICS_CA_AUTO_ADDR_LIST = NO.
> Window #1 is set with EPICS_CA_ADDR_LIST= IP1, while
> window #2 is set with EPICS_CA_ADDR_LIST= IP2.
> Is ther any other better way ? I wanted to make sure that certain
> clients CA the specified IP, instead of the other one. Thus, I
> disconnected
> one of the cable going to that specified N.I. However, when I do that,
> all the medm clients on both windows became disconnected from the IOC.
> Any pointer highly appreciated,
> Kate
- CA for IOCs w/ dual NICs Kate Feng
RE: CA for IOCs w/ dual NICs Liyu, Andrei
<2005>
Re: CA for IOCs w/ dual NICs Andrew Johnson
<2005>
