Hello Li Gang, The standard VIPC-616 without the -01 option does need to be modified in order for slot D to work properly. As delivered by SBS the VIPC610 has IRQ0 of slot D connected to the VMEbus level 7 interrupt, and IRQ1 of slot D does not cause a VMEbus interrupt at all. Under vxWorks on the MC680x0 family a level 7 interrupt level may only be connected to a service routine that does not make any calls to vxWorks routines. Thus with a VIPC610 board slot D should not be used for modules that generate interrupts. The VIPC610-01 board option is free of this problem. To modify the VIPC-616 to an option -01: 1. Change the program in U17 to G52211 2. Change the program in U12 to G52212 3. Remove any shunts and wires on E9, E10, E11, and E12. 4. Add wire wrap wires: E10-1 to E12-8 E10-2 to E12-5 E10-3 to E12-2 E10-4 to E12-1 5. Add shunts E11-3 to E12-3 E11-4 to E12-4 E11-6 to E12-6 E11-7 to E12-7 This option changes the interrupt map on the VIPC-616 to look like that of two VIPC-310s. Also, if you need I do have the new PAL code. I think that I should also mention to you that we at APS have found a problem with the VIPC-616 board even with the -01 option. The problem ocurrs only with a PPC and at least 2 interrupters and happens only during back to back interrupts. It seems that the VIPC-616 board requires the VME bus IACK* to toggle when servicing interrupts. Without getting into all the gory details what happens then is the VME bus gets a bus error (BERR*) and the CPU wiats for a timeout of about 250us before going on to the next bus cycle. This may or moay not be a problem for you though; however, you will probably miss some data from the VIPC-616 when this happens. I have information on this modification as well but it requires that a chip be removed from the board, a couple of board traces cut and a PAL code change in U12. Future purchases of these board should be the VIPC-626ET instead of the VIPC-616 as the 626 does not have these problems. Marty Smith ANL/APS Controls Group Mark Rivers wrote: Dear Li Gang,
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
