1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Logarithmic conversion / Breakpoint tabes
To: "Gavin Smith" <[email protected]>, <[email protected]>
Date: Tue, 29 Mar 2005 07:18:14 -0600
Hi Gavin,
> I have an Ai record which gets raw data from a pressure (vacuum?)
sensor
> measured by the PLC. The raw data ranges from 0 to 256000 and
represents
> a Torr of 1e-11 through to 1e-3. I am wanting to convert this into the
> engineering units, but as far as I can see only linear styles of
> conversion are supported. I could make a breaktable with some values
in
> it, but if I understand correctly the gaps between the points will be
> interpolated linearly, and will therefore suffer some error.
For the vacuum gauge controllers we use (HPS MKS) I wrote device support
in C.  That was necessary because there are things that need to be done
at iocInit, like asking what type of gauge is connected to each of 4
inputs (to set HOPR and LOPR), what units the gauge is using (torr mbar,
etc.).  With device support it is easy to do the conversion in C and put
the result into the VAL field of the ai record, returning 2
(DO_NOT_CONVERT).
Prev: RE: Logarithmic conversion / Breakpoint tabes Owens, PH (Peter)
Next: Re: The later four ports of IP-Octal-232 could not work. Martin L. Smith
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Logarithmic conversion / Breakpoint tabes Maren Purves
Next: RE: Logarithmic conversion / Breakpoint tabes Dalesio, Leo `Bob`
