1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: R3.14.7 errlog problem
To: [email protected]
Date: Thu, 17 Mar 2005 14:39:25 -0600
On 15FEB2005 a patch was made available to fix a problem in errlog on vxWorks powerPC processors.
The patch introduced a problem that causes IOC failure if errlogPrintf is call from an interrupt handler.
The R3.14.7 site
http://www.aps.anl.gov/epics/base/R3-14/7.php
Look for KnownProblems
provides an updated patch file and also the latest errlog.c
Ron Sluiter discovered and found the cause of the original problem. Finding the cause was NOT easy. He also discovered the latest problem.
Thanks Ron!!!
Marty Kraimer
Prev: Re: Reading a synchronous input with an asynchronous device. Emmanuel Mayssat
Next: Re: Solaris 9, vxWorks, Slow Boot Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: dbStaticLib in R3.14.7 Benjamin Franksen
