Emmanuel Mayssat wrote:
I use "dbLoad" files such as this one:
# HPS937A - LOAD RECORD INSTANCES
# Serial Port Number = ${SPN}
# Serial Configuration = 9600 8N1
dbLoadRecords("${DB_DIR}/HPS937A.db","deviceName=${IOCNAME}:HPS937A:${SPN}:${PAD},
serialPortNumber=${SPN},primaryAddress=${PAD},
baudRate=${BR},numberOfDataBits=8,parity=0,numberOfStopBits=1");
those can be considered as template for intanciation.
In the stcmd file ( iocsh script ), I source those template files with a
command as follow:
< /DBL_DIR/HPS937A.dbl
Now, before I source this file, I need to epicsSetEnv all the variables
such as ${SPN} and ${PAD} and ${IOCNAME}. ( or they need to be defined
in the linux shell )
Now, I would like to include in my dbl files a command that says:
If this variable is not set, then set it to this value.
This would enable me to just set the vars that are meaningful.
For example, baudRate could default to 9600. But if I really want to
change it I can do so with epicsSetEnv(BR,19200).
Why not just source a script which sets the default values of all the
environment varaibles before sourcing any of the other scripts which then
optionally override the values and use them.
Eric Norum [email protected]
Advanced Photon Source Phone: (630) 252-4793
Argonne National Laboratory
- Re: if-then-else in iocsh Emmanuel Mayssat
- if-then-else in iocsh Emmanuel Mayssat
- Re: if-then-else in iocsh Andrew Johnson
- Re: if-then-else in iocsh Maren Purves
<2005>
<2005>
ANJ, 02 Sep 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
