g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
Subject: if-then-else in iocsh
From: Emmanuel Mayssat <emmanuel_mayssat@lynceantech.com>
To: tech-talk@aps.anl.gov, Emmanuel Mayssat <emmanuel_mayssat@lynceantech.com>
Date: Fri, 28 Jan 2005 10:08:08 -0800
Hello,
I would like to check for the settings of an environment variable in
iocsh. If the envrionment variable is not set, then I want to set it to
a default value.
Is there any way to do that ?
Emmanuel Mayssat
Lyncean Technologies, Inc.
Direct: 650/320-8300 x409
Cell: 650/793-0626
Re: if-then-else in iocsh Andrew Johnson
Prev: Re: write access through ca gateway Kenneth Evans, Jr.
Next: Re: if-then-else in iocsh Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
