I am trying to compile cmlog R2.1 PROD-2 on linux debian system. I exported the WRAPPER_ROOT and ran make linux, but somewhere along the way this error(s) happened. The daemon also failed to build, most probably because of this error. Should I do anything else before running make? Best regards, Gasper Pajor make[3]: Entering directory `/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0/ace' mkdir -p .obj/Linux-i386 g++ -I. -I.. -DLinux -g -c ACE.cpp -o .obj/Linux-i386/ACE.o ACE.cpp:333:1: warning: "RLIMIT_NOFILE" redefined In file included from /usr/include/sys/resource.h:25, from ../ace/OS.h:829, from ../ace/ACE.h:19, from ../ace/IPC_SAP.h:19, from ACE.cpp:2: /usr/include/bits/resource.h:64:1: warning: this is the location of the previous definition g++ -I. -I.. -DLinux -g -c Addr.cpp -o .obj/Linux-i386/Addr.o g++ -I. -I.. -DLinux -g -c ARGV.cpp -o .obj/Linux-i386/ARGV.o g++ -I. -I.. -DLinux -g -c Date_Time.cpp -o .obj/Linux-i386/Date_Time.o g++ -I. -I.. -DLinux -g -c Event_Handler.cpp -o .obj/Linux-i386/Event_Handler.o g++ -I. -I.. -DLinux -g -c FIFO.cpp -o .obj/Linux-i386/FIFO.o g++ -I. -I.. -DLinux -g -c FIFO_Recv.cpp -o .obj/Linux-i386/FIFO_Recv.o g++ -I. -I.. -DLinux -g -c FIFO_Recv_Msg.cpp -o .obj/Linux-i386/FIFO_Recv_Msg.o g++ -I. -I.. -DLinux -g -c FIFO_Send.cpp -o .obj/Linux-i386/FIFO_Send.o g++ -I. -I.. -DLinux -g -c FIFO_Send_Msg.cpp -o .obj/Linux-i386/FIFO_Send_Msg.o g++ -I. -I.. -DLinux -g -c FILE.cpp -o .obj/Linux-i386/FILE.o g++ -I. -I.. -DLinux -g -c FILE_Addr.cpp -o .obj/Linux-i386/FILE_Addr.o g++ -I. -I.. -DLinux -g -c FILE_Connector.cpp -o .obj/Linux-i386/FILE_Connector.o g++ -I. -I.. -DLinux -g -c FILE_IO.cpp -o .obj/Linux-i386/FILE_IO.o g++ -I. -I.. -DLinux -g -c Get_Opt.cpp -o .obj/Linux-i386/Get_Opt.o g++ -I. -I.. -DLinux -g -c Handle_Set.cpp -o .obj/Linux-i386/Handle_Set.o Handle_Set.cpp: In member function `void ACE_Handle_Set::sync(int)': Handle_Set.cpp:111: error: 'struct fd_set' has no member named '__fds_bits' Handle_Set.cpp: In member function `void ACE_Handle_Set::set_max(int)': Handle_Set.cpp:131: error: 'struct fd_set' has no member named '__fds_bits' Handle_Set.cpp:136: error: 'struct fd_set' has no member named '__fds_bits' Handle_Set.cpp: In member function `void ACE_Handle_Set_Iterator::operator++() ': Handle_Set.cpp:172: error: 'const struct fd_set' has no member named ' __fds_bits' Handle_Set.cpp:183: error: 'const struct fd_set' has no member named ' __fds_bits' Handle_Set.cpp: In constructor ` ACE_Handle_Set_Iterator::ACE_Handle_Set_Iterator(const ACE_Handle_Set&)': Handle_Set.cpp:201: error: 'const struct fd_set' has no member named ' __fds_bits' Handle_Set.cpp:205: error: 'const struct fd_set' has no member named ' __fds_bits' make[3]: *** [.obj/Linux-i386/Handle_Set.o] Error 1 make[3]: Leaving directory `/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0/ace' make[2]: *** [linux-redhat6.0-x86] Error 2 make[2]: Leaving directory `/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0/ace' make[1]: Leaving directory `/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0'
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
