Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
Subject: Re: cmlog compile problems
To: gasper.pajor@cosylab.com, tech-talk@aps.anl.gov
Date: Wed, 06 Oct 2004 15:26:36 -0400
I am trying to compile cmlog R2.1 PROD-2 on linux debian system.
I exported the WRAPPER_ROOT and ran make linux, but somewhere along the way this error(s) happened.
The daemon also failed to build, most probably because of this error.
Should I do anything else before running make?
Best regards,
  Gasper Pajor
make[3]: Entering directory `/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0/ace'
mkdir -p .obj/Linux-i386
g++ -I. -I.. -DLinux -g -c ACE.cpp -o .obj/Linux-i386/ACE.o
ACE.cpp:333:1: warning: "RLIMIT_NOFILE" redefined
In file included from /usr/include/sys/resource.h:25,
from ../ace/OS.h:829,
from ../ace/ACE.h:19,
from ../ace/IPC_SAP.h:19,
from ACE.cpp:2:
/usr/include/bits/resource.h:64:1: warning: this is the location of the previous definition
g++ -I. -I.. -DLinux -g -c Addr.cpp -o .obj/Linux-i386/Addr.o
g++ -I. -I.. -DLinux -g -c ARGV.cpp -o .obj/Linux-i386/ARGV.o
g++ -I. -I.. -DLinux -g -c Date_Time.cpp -o .obj/Linux-i386/Date_Time.o
g++ -I. -I.. -DLinux -g -c Event_Handler.cpp -o .obj/Linux-i386/Event_Handler.o
g++ -I. -I.. -DLinux -g -c FIFO.cpp -o .obj/Linux-i386/FIFO.o
g++ -I. -I.. -DLinux -g -c FIFO_Recv.cpp -o .obj/Linux-i386/FIFO_Recv.o
g++ -I. -I.. -DLinux -g -c FIFO_Recv_Msg.cpp -o .obj/Linux-i386/FIFO_Recv_Msg.o
g++ -I. -I.. -DLinux -g -c FIFO_Send.cpp -o .obj/Linux-i386/FIFO_Send.o
g++ -I. -I.. -DLinux -g -c FIFO_Send_Msg.cpp -o .obj/Linux-i386/FIFO_Send_Msg.o
g++ -I. -I.. -DLinux -g -c FILE.cpp -o .obj/Linux-i386/FILE.o
g++ -I. -I.. -DLinux -g -c FILE_Addr.cpp -o .obj/Linux-i386/FILE_Addr.o
g++ -I. -I.. -DLinux -g -c FILE_Connector.cpp -o .obj/Linux-i386/FILE_Connector.o
g++ -I. -I.. -DLinux -g -c FILE_IO.cpp -o .obj/Linux-i386/FILE_IO.o
g++ -I. -I.. -DLinux -g -c Get_Opt.cpp -o .obj/Linux-i386/Get_Opt.o
g++ -I. -I.. -DLinux -g -c Handle_Set.cpp -o .obj/Linux-i386/Handle_Set.o
Handle_Set.cpp: In member function `void ACE_Handle_Set::sync(int)':
Handle_Set.cpp:111: error: 'struct fd_set' has no member named '__fds_bits'
Handle_Set.cpp: In member function `void ACE_Handle_Set::set_max(int)':
Handle_Set.cpp:131: error: 'struct fd_set' has no member named '__fds_bits'
Handle_Set.cpp:136: error: 'struct fd_set' has no member named '__fds_bits'
Handle_Set.cpp: In member function `void ACE_Handle_Set_Iterator::operator++()
Handle_Set.cpp:172: error: 'const struct fd_set' has no member named '
__fds_bits'
Handle_Set.cpp:183: error: 'const struct fd_set' has no member named '
__fds_bits'
Handle_Set.cpp: In constructor `
ACE_Handle_Set_Iterator::ACE_Handle_Set_Iterator(const ACE_Handle_Set&)':
Handle_Set.cpp:201: error: 'const struct fd_set' has no member named '
__fds_bits'
Handle_Set.cpp:205: error: 'const struct fd_set' has no member named '
__fds_bits'
make[3]: *** [.obj/Linux-i386/Handle_Set.o] Error 1
make[3]: Leaving directory `/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0/ace'
make[2]: *** [linux-redhat6.0-x86] Error 2
make[2]: Leaving directory `/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0/ace'
make[1]: Leaving directory `/home/gpajor/download/cmlog/CMLOG-R2_1-PROD-2/C++/SACE-4.0'
Hi, Gasper:
We have not compiled cmlog on debian linux distribution. However, we have compiled cmlog on various RedHat linux distributions. The error messages you saw were related to a incorrect ace config.h file and incorrect Linux configuration in the Makefile.config. In the CMLOG/C++/SACE-4.0/Makefile.config, you may want to change linux: or linux-th: to point to linux-redhat8-x86(th). Similarly you want to make the same change to CMLOG/Makefile.config. Even though there are differences between RedHat and Debian distributions, I hope the redhat configuration will serve as a starting point for your debian box. If you have any question, please let us know. Thanks.
Jie Chen
Thomas Jefferson National Accelerator Facility
12000, Jefferson Ave.
Newport News, VA 23606
(757)269-5046 (office) (757)269-6248 (fax)
chen@jlab.org
Prev: cmlog compile problems Gasper Pajor
Next: Not-a-number (nan) issues Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017
· EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
