1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re:
To: [email protected]
Date: Thu, 23 Sep 2004 11:27:38 -0700
You might like to consider switching to the TMPC810 this is also a two
channel CAN bus controller based on the Philips SJA1000.
This same chip is used on the TIP810 for which EPICS support exists.
All I did was replace the Industry Pack layer with a pci layer and leave
the rest of the EPICS source code intact (well almost).
If you plan to use it on an Intel x86 VxWorks system a small modification needs to be made to the BSP. A MMU mapping entry for
the TPMC810 or TMPC816 must be made prior to MMU initialization.
If anyone would like the source code please ask.
Graham
J. Frederick Bartlett wrote:
  Has anyone developed device and (I presume) driver support for the TEWS
TPMC816 Extended CANBUS PMC module? Is anyone interested or considering this
device?
Fritz
|Graham Waters, Control System Eng phone: (604)-222-1047 ext 6531 |
|TRIUMF --- University of B.C, Fax: (604)-222-7307 |
|Vancouver, BC, Canada e-mail: [email protected] |
|http://isacwserv.triumf.ca/edevel/homepage/graham01.html |
[no subject] J. Frederick Bartlett
Prev: Re: Andrew Johnson
Next: 3.13 to 3.14 issue john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: [no subject] J. Frederick Bartlett
Next: [no subject] J. Frederick Bartlett
