1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: 3.13 to 3.14 issue
To: tech talk <[email protected]>
Date: Fri, 24 Sep 2004 17:41:30 -0400
I am moving an application from EPICS 3.13.6 on VxWorks to 3.14.6 on Linux and
have observed the following:
In the 3.13 case, the application src directory contains a dbd include file.
If the project name is test, this file is testInclude.dbd. The include file
is automatically included in the final .dbd file for the project.
Version 3.14 works the same way. However, if this auto-include dbd file is
present, the sequencer is not visible from the IOC shell (i.e. help did not
give seq and typing seq gave an "unknown command" response).
Doing a "make clean uninstall install" made no difference. I had to eliminate
the dbd include file.
Is this a known issue?
John Sinclair
Prev: Re: Graham Waters
Next: RE: 3.13 to 3.14 issue Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Andrew Johnson
