We are starting to examine the use of ControlLogix PLCs at
IPNS and I am looking at Kay’s driver for Ethernet/IP. We now have
our first test setup going and we are looking at some of the subtleties with
how to access various types of tags. I am very novice with any PLC so
please forgive my awkward use of terminology.
It appears that the only tags that are accessible to the
EPICS driver are ones provided at the controller level ( in RSLogix 5000 App).
Is this correct?
We have been able to access inputs (ai & bi) OK but have
been having some trouble with binary outs. So far we have avoided arrays
altogether. We have a binary out module ( relay out I believe ). We
can control an output of this directly using the base tag Local:2:O.Data[3]
with a binary output record. However, when we create another tag which
aliases Local:2:O.Data[3] and point the record at this, we can turn the output
on but cannot turn it off. I have an EPICS screen that allows me to
change the value and monitor the RVAL field. Here I see the new value (0)
temporarily reflected in the RVAL &VAL fields but then it goes back to 1.
No change is seen in RSLogix 5000. We can reset the Value with RSLogix
5000 and repeat the process. The same effect is seen for any “soft”
tag. BTW the soft records that I have are type BOOL.
Any ideas?
John Hammonds
Data Acquisition Systems Manager
Intense Pulsed Neutron Source
[email protected]
(630)252-5317
