Hi JOhn,
The reason it is going back to 1 - is that the driver
reads the output and reflects that value in the database.
This is done as there may be a different master for the
outputs - like a Allen-BRadley PanelMate.
For outputs, it is a good idea to have the IOC write to a
boolean that is a request to drive an output. Make the
output momentary by setting the HIGH field. Have it write
to a soft variable in the PLC. Then the PLC can compute
any interlock logic necessary to determine if it is safe
to write the output.
Kay will have to say more about why the output may not be
changing.
Bob
On Tue, 24 Aug 2004 20:54:21 -0500
"Hammonds, John P." <[email protected]> wrote:
We are starting to examine the use of ControlLogix PLCs
at IPNS and I am
looking at Kay's driver for Ethernet/IP. We now have our
first test
setup going and we are looking at some of the subtleties
with how to
access various types of tags. I am very novice with any
PLC so please
forgive my awkward use of terminology.
It appears that the only tags that are accessible to the
EPICS driver
are ones provided at the controller level ( in RSLogix
5000 App). Is
this correct?
We have been able to access inputs (ai & bi) OK but have
been having
some trouble with binary outs. So far we have avoided
arrays
altogether. We have a binary out module ( relay out I
believe ). We
can control an output of this directly using the base tag
Local:2:O.Data[3] with a binary output record. However,
when we create
another tag which aliases Local:2:O.Data[3] and point the
record at
this, we can turn the output on but cannot turn it off.
I have an EPICS
screen that allows me to change the value and monitor the
RVAL field.
Here I see the new value (0) temporarily reflected in the
RVAL &VAL
fields but then it goes back to 1. No change is seen in
RSLogix 5000.
We can reset the Value with RSLogix 5000 and repeat the
process. The
same effect is seen for any "soft" tag. BTW the soft
records that I
have are type BOOL.
Any ideas?
John Hammonds
Data Acquisition Systems Manager
Intense Pulsed Neutron Source
[email protected]
(630)252-5317
Bob Dalesio
[email protected]
410 557 0297 Maryland
505 699 1632 Cell Phone
- Re: EPICS Ethernet/IP & ControlLogix Kay-Uwe Kasemir
- EPICS Ethernet/IP & ControlLogix Hammonds, John P.
<2004>
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
