Mark Rivers wrote:
> Hi Dorothea,
> > may I ask once again for drivers: Is someone using carrier boards on
> > VME-systems running RTEMS together with A/D- and D/A-converter
> > Industry Packs?
> > We would like to install Industry Packs with 16bit A/D and D/A
> > converters respectively with a throuput of >=100kHz. We shortlist the
> > IP235 from Acromag, A/Dconverter and the IP-ADC-8401 from Hytec.
> I have a driver for the Acromag IP330 A/D, which is 16-bits. I also
> have a driver for the Systran DAC-128V D/A, which is 12 bits. Both of
> these are Industry Pack devices. The drivers have been extensively
> rewritten in the last few weeks to use with the new "asyn" package that
> Marty Kraimer mentioned.
> The required packages are "IPAC", "asyn", and my drivers. IPAC is
> maintained by Andrew Johnson. I don't know if it has been tested under
> RTEMS. I doubt if anyone is using my drivers under RTEMS yet, and I
> would guess that there will be a small amount of work required to get it
> all running on RTEMS.
I came across some of 3.14.x compatible drivers lately, and found most
of them RTEMS ready (e.g. using epicsThreadSleep() instead of
taskDelay()). I recalled SPEAR3/SLAC had some IPAC and Hytec drivers
running on RTEMS. Maybe Stephanie Allison knows where is the
web download site.
Cheers,
Kate
- RE: Industry Pack support under RTEMS available? Mark Rivers
RE: Industry Pack support under RTEMS available? Allison, Stephanie
<2004>
<2004>
