1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Industry Pack support under RTEMS available?
To: "Dorothea Wehler" <[email protected]>, "EPICS TechTalk" <[email protected]>
Date: Tue, 17 Aug 2004 08:47:25 -0500
Hi Dorothea,
> may I ask once again for drivers: Is someone using  carrier boards on
> VME-systems running RTEMS together with  A/D- and D/A-converter
> Industry Packs?
> We  would like to install Industry Packs with 16bit A/D and D/A
> converters respectively with a throuput of >=100kHz. We shortlist the
> IP235 from Acromag, A/Dconverter and the IP-ADC-8401 from Hytec.
I have a driver for the Acromag IP330 A/D, which is 16-bits.  I also
have a driver for the Systran DAC-128V D/A, which is 12 bits.  Both of
these are Industry Pack devices.  The drivers have been extensively
rewritten in the last few weeks to use with the new "asyn" package that
Marty Kraimer mentioned.
The required packages are "IPAC", "asyn", and my drivers.  IPAC is
maintained by Andrew Johnson.  I don't know if it has been tested under
RTEMS.  I doubt if anyone is using my drivers under RTEMS yet, and I
would guess that there will be a small amount of work required to get it
all running on RTEMS.
Mark Rivers
Re: Industry Pack support under RTEMS available? Kate Feng
Prev: Industry Pack support under RTEMS available? Dorothea Wehler
Next: Re: Industry Pack support under RTEMS available? Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: Industry Pack support under RTEMS available? Till Straumann
