EPICS
on Google+
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012
Subject: LINUX/Comedi experience?
To: tech-talk@aps.anl.gov
Date: Tue, 13 Jul 2004 11:41:02 -0400
We are running EPICS 3.14.4 Linux IOC with the Comedi driver
for the National Instrument PCI-MIO-16E-1 multifunction board.
Only ai, ao, bi, bo EPICS synchronous device supports are
implemented so far.
We are going to get the counter of the PCI-MIO board working
with the synApps scaler record. Yet the Comedi counter API
is unstable and undocumented. We have to read the Comdei code
in order to get anything done.
Hopefully we could work out a simple match of the Comedi
"command" constructs to the EPICS asynchronous operations for
the scaler and other records. We have not decided if making
Linux system calls directly would be simpler.
The comedi_parport driver can also be used for EPICS bi, bo
operations. This is free EPICS bit I/O using the standard
PC parallel port.
Once the device support of the commonly used EPICS records
are worked out, the generalization to other Comedi supported
hardware should be much easier.
Ivan So
NSLS/BNL
Lawrence T. Hoff wrote:
> I just finished reading the article on Comedi in the
> August 2004 edition of LINUX Journal. Apparently, Comedi
> is an open-source effort to support many PC-based I/O
> modules. I had never heard of it before. Do any LINUX/EPICS
> users have experience with Comedi to share?
>	For the curious, here is a list of supported H/W:
> http://www.comedi.org/hardware.php
> -- Larry
Prev: Re: Tektronix 3000B Nicholas P DiMonte
Next: Fwd: Re: APS Hardware Catalog - beta version Pete R Jemian
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012
Prev: Re: LINUX/Comedi experience? Paul Sichta
Next: Re: LINUX/Comedi experience? Brian McAllister
· EPICSv4 · IRMIS · Tech-Talk · Bugs · Documents · Links · Google · Licensing ·
