1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: MVME5110
To: "Dirk Zimoch" <[email protected]>, "TECHTALK" <[email protected]>
Date: Wed, 14 Apr 2004 07:48:18 -0500
Dirk,
> when I reboot a Motorola MVME5110, it takes ages (30 sec to be exact)
> until the vxWorks boot procedure starts. It takes another 30 seconds
> starting the loaded vxWorks kernel.
> Does anyone know what the board is doing in all that time?
> The MVME2306 have never waited for so long. Can I reduce that time?
I see exactly the same 30 second delays on MVME2700 when they are connected to certain models of Ethernet switches.  I believe it is a problem with the 10/100 or full/half duplex negotiation.  I have always been able to eliminate the problem by putting an Ethernet hub between those switches and the MVME2700.  I believe that Andrew Johnson made changes to the bootrom code and BSP to try to fix the problem, but they did not help.
Mark Rivers
Re: MVME5110 Dirk Zimoch
Prev: MVME5110 Dirk Zimoch
Next: Re: MVME5110 Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: LabVIEW Channel Access Client Willem Blokland
