It is very EDM like in that you just put an indicator like a waveform graph on the front-panel, give it the name of an EPICS PV, save and close the panel. You can then run the panel by selecting it from a list in the start screen utility. This utility, creates a background task that will scan the PVs and send data to the indicators on the front-panel. It is in the early stages and supports only a limited number of LabVIEW's graphs and indicators (waveform, chart, table, single indicators of float type). You can also do settings and add program code to analyze the data or save to disk. Currently, it can only scan PVs not monitor. The code should work on Windows, Linux, and Mac OS X and requires LabVIEW 7. Dave Purcell can hopefully demo this to the EPICS conference goers. Willem Blokland
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
