1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problems of Channel Archiver
To: Wang Yanke <[email protected]>
Cc: Techtalk <[email protected]>
Date: Tue, 16 Mar 2004 12:40:37 +0100
Wang Yanke wrote:
 When I tried to archive the vacuum data with
ChannelArchiver, I got some data like:
03/09/2004 15:58:23.254187014   0.000
03/09/2004 15:58:43.254186214   0.000
03/09/2004 15:59:00.000000000   0.000
03/09/2004 15:59:03.254185414   0.000
03/09/2004 15:59:20.000000000   0.000
03/09/2004 15:59:40.000000000   0.000
03/09/2004 16:00:00.000000000   0.000
03/09/2004 16:00:20.000000000   0.000
03/09/2004 16:00:40.000000000   0.000
03/09/2004 16:00:43.254181414   0.000
I have retrievaled it with CGIExport or ArchiveExport many times, but
the results were disappointing.
So, Why can't I get the same proper value(e.g. 1.324e-07) as using
"caget" instead of zero?
Furthermore, why the time interval is not the value i set in the .cfg
file(20 seconds)?
Is there something wrong with the configuration of the ArchiveEngine
or the retrieval tools?
How can I get the data I want?
The reason for that behaviour is, that the Export-functions of the ChannellArchiver
(every function, that formats floats/doubles into strings) honours the PREC-field of
the connected PV. It's like
sprintf( "%*f", prec, value )
In some cases, it would be better to use engineering- or scientific-notation instead of decimal notation - or even ignore the PREC at all. As an exception, a PREC of 0 is indeed ignored...
We had the same problems with our vacuum values here at BESSY and started to store the logarithmic values instead.
The good thing is: The archive has all the values with full accuracy, so once you change the formatting of the output, you'll get your values just like you expect them to be.
But none of the bundled export tools ignores the PREC-field if it is set to something other than 0.
The "20 seconds" problem actually isn't a problem.
If a new value arrives via ChannelAccess, it is stored with the accurate timestamp. The other values are not even stored in the archive (Kay, correct me if I'm wrong). It's the output-functions again, that produce these repeated values.
I know this is not really helpful, but it's an attempt to explain what happens...
Is ther any guideline on whether and how to handle/honour the PREC field at all?
Thomas
Re: Problems of Channel Archiver Bob Dalesio
Re: Problems of Channel Archiver Steven Hartman
Problems of Channel Archiver Wang Yanke
Prev: Re: More CA questions Benjamin Franksen
Next: Re: Problems of Channel Archiver Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Problems of Channel Archiver Wang Yanke
