>ioc13lab> iocClockSyncWithNTPserver: sntpcTimeGet S_sntpcLib_TIMEOUT
That error message problem was EPICS IOC dose not connected NTP Servers.
First you must checking your NTP servers alive and it?s better synchronization with GPS time.
Second route add, time zone, environment variable to boot script files.
My startup script "st.cmd" files examples.
#141.223.182.106 ? NTP server
#141.223.48.99 ? EPICS IOC subnet
routeAdd("141.223.182.106", "141.223.48.99")
putenv("TIMEZONE=KST::-540:000000:000000") #KOREA zone
putenv("EPICS_TS_MIN_WEST=-540")
putenv("EPICS_TS_NTP_INET=141.223.182.106") #PLS NTP server IP
# This comment helped Timo, who SLS Control people.
# Time stamp support software configuration:
# The parameters:
# 1. master_indicator: 1=master timing IOC, 0=slave, default is slave.
# 2. sync_rate_seconds: The clock sync rate in seconds, default 10 seconds.
# 3. clock_rate_hz: The frequency in hertz of the clock.
# Default 1000Hz for the event system
# and IOC's internal clock rate when soft timing is used.
# 4. master_port: The UDP port for a master to receive ts requests,
# default 18323.
# 5. slave_port: The UDP port for a slave to receive time stamps
# from a master.
# 6. time_out: UDP information request time out in milliseconds, default 250ms.
# 7. Operation mode: 0=normal operation, 1=force soft timing.
#more details read to EPICS IOC manuals
TSconfigure(1, 10, 1000,18323,18322,0,0)
and you type "date" again.
ioc:#01->date
Dec 15, 2003 07:40:41.320400198
value = 32 = 0x20 = ' '
Kiman Ha,
PLS Control Group
> -----Original message-----
> From: "MarkRivers"
> To: [email protected]
> Date: 12/15/2003(Mon)00:51
> Subject: Network time server for vxWorks booting from Darwin
> Folks,
> I am setting up an EPICS system where a vxWorks 5.4.2 IOC will boot from a Mac Darwin host. FTP and NFS are working fine, so the IOC boots OK. However, it then prints the message:
> which means that it was not able to get the time from the boot host. Typing "date" at the vxWorks prompt shows that indeed it has not set the date and time correctly.
> In the past I have successfully booted vxWorks IOCs from Windows systems by enabling the "timed" service provided by Hummingbird's inetd.
> I am confused about how to enable a time server on Darwin that the IOC can use. By default neither "ntpd" nor "timed" seem to be running (as judged from "ps -ax"). Manually starting "ntpd" and/or "timed" did not help, the IOC still does not get the time when it boots.
> Does anyone have an idea on what time server I should be running for vxWorks to be able to get the time, and how to correctly start that on Darwin?
> Thanks,
> Mark Rivers
Network time server for vxWorks booting from Darwin Mark Rivers
Re: Network time server for vxWorks booting from Darwin Ernest L. Williams Jr.
<2003>
Re: Network time server for vxWorks booting from Darwin Eric Norum
SBS VIPC616 IP Carrier Ned Arnold
<2003>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
