Mark Rivers wrote:
Ernest,
Also, check Darwin for a ntp configuration file. There may
be a default security level just like in LINUX:
That was basically the problem. With the default settings of ntpd on Darwin, and with the default ntp.conf, authentication is enabled. I have now copied our Linux ntp.conf file to the Darwin system, and it has a line "authenticate no". Restarting ntpd to use that file fixed the problem. I also realize now that my boot host does not actually have to provide ntp time, I can set the environment variable EPICS_TS_NTP_INET to point to another time server.
You could also specify the NTP server in a DHCP option field. This might be easier than messing around with environment variables.
Eric Norum [email protected]
Advanced Photon Source Phone: (630) 252-4793
Argonne National Laboratory
- RE: Network time server for vxWorks booting from Darwin Mark Rivers
Re: about edm1-9-6 Andy Foster
SBS VIPC616 IP Carrier Ned Arnold
<2003>
Re: Network time server for vxWorks booting from Darwin hkm
<2003>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
