Ernest,
We intend to modularize synApps to a greater extent in the next release
which we are planning will occur in January. The sscanRecord will then
be in it's own module.
John.
Ernest L. Williams Jr. wrote:
We use the sscanRecord from synApps and look forward to it under R3.14.
Could this be unbundled and distributed like the motor software?
Ernest
SNS
On Fri, 2003-12-05 at 16:01, Marty Kraimer wrote:
The next 3.14 release will support put callbacks for database channel access
links. This is being done so that synapps can remove it's dependence on recDynLink.
3.13 and early versions of 3.14 has support for scanRecord. This was removed
from 3.14 because it required recDynLink. Now that put callback links will be
supported the scanRecord could be easily modified so that it no longer requires
recDynLink.
The question I have is does anyone use scanRecord?
Synapps provides sscanRecord which provides more functionality than scanRecord
so is scanRecord still needed?
Marty Kraimer
- scanRecord for 3.14 Marty Kraimer
- Re: scanRecord for 3.14 Ernest L. Williams Jr.
Re: scanRecord for 3.14 Tim Mooney
<2003>
RE: scanRecord for 3.14 Redman, Russell O.
<2003>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
